max55uk Posted May 1, 2007 Share Posted May 1, 2007 Hi Guys, I'm in search for a Rear Drivers side Upper Link, Failed its MOT due to too much play, just wanted to know if anyone has had this link replaced?, where do i get this link from? any recommended breakers out there who can send it out to me? btw Its a 1994/ N/A 5 speed Model Any advice much apreciated, Thanks Link to comment Share on other sites More sharing options...
Nic Posted May 2, 2007 Share Posted May 2, 2007 Can you ask the garage to identify the part you need from this EPC diagram, I'll then be able to tell you the part number you need. I'm guessing that they mean you need a new upper arm (the Y shaped part at the top of the pic). I can supply OEM suspension components at a fraction of the UK T dealer prices, but it would take around 4-5 weeks to order. If you need urgently then your local Toyota dealer should be able to get for you. http://img224.imageshack.us/img224/82/rearsuspensionepcea3.jpg Link to comment Share on other sites More sharing options...
Dnk Posted May 2, 2007 Share Posted May 2, 2007 how much for the upper arm please nic sorry for the highjack Link to comment Share on other sites More sharing options...
max55uk Posted May 2, 2007 Author Share Posted May 2, 2007 Cheers mate, i'l get onto the garage & get back to you, Regards Link to comment Share on other sites More sharing options...
keron Posted May 2, 2007 Share Posted May 2, 2007 i think ibrar at pro-alloys on here has a few...he's a trader on here... Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 2, 2007 Share Posted May 2, 2007 Hi Guys, I'm in search for a Rear Drivers side Upper Link, Failed its MOT due to too much play, just wanted to know if anyone has had this link replaced?, where do i get this link from? any recommended breakers out there who can send it out to me? btw Its a 1994/ N/A 5 speed Model Any advice much apreciated, Thanks Hi, Is the play coming from the bush or the knuckle joint? Reason I ask is I can supply replacement bushes for it if required, might work out a bit cheaper than a whole arm! Cheers Paul Link to comment Share on other sites More sharing options...
max55uk Posted May 2, 2007 Author Share Posted May 2, 2007 just to confirm it is the Y Shaped arm i require, Link to comment Share on other sites More sharing options...
Nic Posted May 2, 2007 Share Posted May 2, 2007 how much for the upper arm please nic sorry for the highjack Hi Dunk £109 each + postage. cheers Link to comment Share on other sites More sharing options...
max55uk Posted May 2, 2007 Author Share Posted May 2, 2007 Hi Dunk £109 each + postage. cheers is that the same arm i require?? Link to comment Share on other sites More sharing options...
Nic Posted May 2, 2007 Share Posted May 2, 2007 is that the same arm i require?? Yes, although it'll probably be a lot more expensive from a UK Toyota dealer, I'd guess. Link to comment Share on other sites More sharing options...
max55uk Posted May 2, 2007 Author Share Posted May 2, 2007 whats the postage cost, i'm over in west yorkshire Link to comment Share on other sites More sharing options...
max55uk Posted May 2, 2007 Author Share Posted May 2, 2007 just realised your delivery time is upto 4 weeks?, i do need them pretty urgently, Link to comment Share on other sites More sharing options...
Nic Posted May 2, 2007 Share Posted May 2, 2007 whats the postage cost, i'm over in west yorkshire Not sure, but would guess around £20 to UK. The problem maybe the order time, I'd need to order from Toyota Japan which would take around 4 weeks, plus 5-7 days airmail to you. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 2, 2007 Share Posted May 2, 2007 I can supply one in 2 weeks for £105 + VAT if that helps? I'm going to stock all these suspension parts from now on as it seems they are wearing quite badly on older higher mileage cars. So if anyone needs them at a reduced price to the UK Toyota price I'll have them here. Link to comment Share on other sites More sharing options...
Dnk Posted May 2, 2007 Share Posted May 2, 2007 Cheers for the prices guys and i know where to come in the future, Toyota arm is £180 ish from Mr T I take it there's no differances between jap and uk spec ? Link to comment Share on other sites More sharing options...
Homer Posted May 2, 2007 Share Posted May 2, 2007 Nic flogging stuff in Technical Ian will have a coronary! Moved to chat. Link to comment Share on other sites More sharing options...
