Advise required for engine rebuild
absz
Right i,m in the process of rebuilding my engine. will be running a T67 p-trim.
what is maxium boost that this turbo can take , and which is the best compression setup to go for? i have been offered some 86.5mm forged pistons with 8.9 c/r at a very good price.
having ferrera inlet/exhaust valves fitted with uprated springs and retainers and ported/polish the head job.
also should i go for aftermarket crankshaft bearing shells or toyota ones ?
ps the fuelling setup will be 780cc injectors,hks fuel rail.two walbro fuel pumps -6 fuel lines and aeromotive FPR.
Unfortunately mate:
I've never seen a compressor map for any precision turbos, or from Boostlogic. For some daft reason they treat them as confidential and won't release them as far as I know.
Terry will almost certainly know. (BTW, where are the pics of the damage ;) ?)
Unfortunately mate:
i'll post them up for you tommorow:d 2 slightly bent conrods and 1 melted piston.:rolleyes:
:cool: love pics of broken engine bits for some reason!
If you don't get a response from Terry you might also want to check on SF, Kean is a member there. If you have the fuel for it I know figures of 2.2bar plus are thrown about, on our 98RON, who knows!
The CR you run depends on a number of factors:
Maximum boost pressure
Target power output
Maximum fuelling available
Detonation sensitivity of the engine
Cam timing
And many other factors!
I have a useful simulation program called Dyno2000 that helps in working out all this stuff.
Let me know if you want to borrow it.
that would be great if you can :)
what the hell happend mate?
car was runnning meggar lean on boost. heavy Detonation just got abit carried away at santa pod. self inflicted really
ouch man I thought the tweeking had sorted it or was the damage already done?
i think the damage was done before i even got to the pod, but my first run the afr went into the 14s at 1 bar:taped:
:oops:
Did sound like it had a few problems when you were running it down the strip matey :(
