UK head lamps
Terminator
9006 bulbs (aka HB4) in the Dipped beam
9005 (aka HB3) in the Main beam
I've got blue 55w bulbs in the Dipped and 100w blues in the Main beam (For Off Road Use Only)
EDIT, These are the ones I'm using.
http://www.autobulbsdirect.co.uk/high_perf.htm
http://www.autobulbsdirect.co.uk/hb3-4_bulbs.htm
They're bloody good for the money, especially the 100w ones.
I'm sure he means £30 for the set.
Phil, try to borrow some standard ones first. The UK beam pattern is far superior to that of the crappy JDM lights.
I tried some uprated bluey bulbs in my UK lights and in honesty, I found the standard ones to be better.
Although the bluey ones looked better :innocent:
Here's another place to get them, quick delivery.
http://www.powerbulbs.com/index.htm
I got some Phillips Premium 9006 for my 97 my facelift lights-dipped beam and they don't fit
The "O" ring on the boss should provide a snug fit, but was about 2mm too big.
The photo shows a 9006 bulb (not the actual one)
9006
I had to remove the "O" ring and reduce the diameter of the boss, I refitted the "O" ring even though I had removed the groove that it used to sit in.
They fit okay but they definately aren't designed to fit the facelift dipped beam.
Next time I need some bulbs for the healights I'm going to go to Halfrauds and measure some first to make sure they fit!
Obviously I am talking modification of the 9005 and 9006's to fit a J-Spec car. The UK bulb holders take the 9005 and 9006 without modifications. The same principles apply to the 9005's though you can modify them by cutting out the socket alignment slots so you can stick a 65 watt 9005 into the dipped beam.
I've got facelift headlights and just checked them, if you open the bonnet and look on the black plastic part above where the bulbs are located there are bulb codes moulded into the plastic. On the top the writing says 'Japan 12V 55W', 'USA HB4 12V', and then slightly lower down near the bulbs is marked '9006J' '9005J'
So the facelift low beam code is 9006J and the high beam is 9005J.
If someone could check a UK-spec and a pre-facelift j-spec hopefully they also have the bulb code marked on and we can get a definitive answer to what bulb fits which headlamp.
Has anybody tried fitting a j-spec bulb (with the smaller diameter body and locking tabs) in a UK-spec headlamp, do they fit?
So it seems both J-spec facelift and pre-facelift headlights are 9005J/9006J
We just need someone to check the UK headlights to confirm that they are definitely 9005/9006 (HB3/HB4 US bulb code.)
It would also be good to establish if the smaller 9005J/9006J will fit the UK headlamps.
At a guess I would say its just a case of trimming some lugs. One thing though, you will probably find that your j-spec bulbs are 55w and there are very much better 65w phillips definitely do them available that go straight in a UK so it might be worth investing in a set and keeping the j-spec bulbs as backups.
