jeremyh Posted May 1, 2007 Share Posted May 1, 2007 http://81.149.22.169/misc/01052007.jpg WTF!! Who what where why when and how has this happened? What do I need to do, and is the car still driveable? Jez Link to comment Share on other sites More sharing options...
flukey-lukey Posted May 1, 2007 Share Posted May 1, 2007 It looks like a water piper with a hole in it, obviously over time the hose has started to perish. Because of the positioning of the hose (and the hole), the steam looks to be making its' way under the plug cover and out through the vents. hope this helps Link to comment Share on other sites More sharing options...
CJ Posted May 1, 2007 Share Posted May 1, 2007 Is it steam or smoke? What happened before it started to do that? Were you driving along? Link to comment Share on other sites More sharing options...
DamanC Posted May 1, 2007 Share Posted May 1, 2007 ooooh fuck! Link to comment Share on other sites More sharing options...
Class One Posted May 1, 2007 Share Posted May 1, 2007 What was your temp gauge reading? Do you have any water left in your expansion tank? (DON'T try and open up your radiator at the minute) Link to comment Share on other sites More sharing options...
Konrad Posted May 1, 2007 Share Posted May 1, 2007 Looks like smoke - oil burning Link to comment Share on other sites More sharing options...
jeremyh Posted May 1, 2007 Author Share Posted May 1, 2007 If it helps, temperature gauge reading was at MAX It was definitely steam, not smoke, and the car was fine for 50 miles prior to this happening...it happened all at once, hence I pulled over to see what was going on. I've just found out that my engine coolant bottle is EMPTY... Link to comment Share on other sites More sharing options...
markrzs Posted May 1, 2007 Share Posted May 1, 2007 white sludge in the oil filler cap ? Link to comment Share on other sites More sharing options...
Pig Posted May 1, 2007 Share Posted May 1, 2007 Oh dear, sounds like you have had some sort of major failure from your rad Temps at max is never a good sign, could have warped head??? Link to comment Share on other sites More sharing options...
Ian W Posted May 1, 2007 Share Posted May 1, 2007 Looks like smoke - oil burning really? I would have said it looks more like steam to me. the temp guage reading max would suggest it's spewed out coolant somewhere. lets hope it's came out externally and the car hasn't ran for too long without any. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted May 1, 2007 Share Posted May 1, 2007 OH Fuck.... Looking at the location of most of the steam, I would say that you have blown a section of your head gsaket out, or a core plug is leaking - badly. Whatever it is, it is NOT an easy fix. Picture looks cool though. Link to comment Share on other sites More sharing options...
Dave Posted May 1, 2007 Share Posted May 1, 2007 looks like you have a hole in a water pipe somewhere on the right hand side .cant see it being head gasket but have you checked for water in the oil? DONT DRIVE IT or you will cook the engine Link to comment Share on other sites More sharing options...
TrickTT Posted May 1, 2007 Share Posted May 1, 2007 Steam appears to be coming from under the plug cover. There's no water pipes under there so I would guess at a cracked head Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted May 1, 2007 Share Posted May 1, 2007 Is there a giant puddle of water under the car, or nothing at all? Did the steam stay there for ages or disperse quickly once you opened the bonnet? Did you lose any power in the run up to stopping? Link to comment Share on other sites More sharing options...
jeremyh Posted May 1, 2007 Author Share Posted May 1, 2007 Hi all, Thanks for the replies, and I've found the problem! It was a water piper with a hole in it, obviously over time the hose has started to perish. Because of the positioning of the hose (and the hole), the steam was making its' way under the plug cover and out through the vents. Will hopefully track down some black water hose tommorrow Thanks again all for the replies, you're never alone in this place! Jez Link to comment Share on other sites More sharing options...
Pig Posted May 1, 2007 Share Posted May 1, 2007 Sounds like a lucky escape. Did you drive it for long when it over heated? Link to comment Share on other sites More sharing options...
jeremyh Posted May 1, 2007 Author Share Posted May 1, 2007 No, as soon as I noticed the steam I pulled over, a guy came over from his house and was really helpful, by the time I pulled over I was only half a mile away from my house anyway. Link to comment Share on other sites More sharing options...
flukey-lukey Posted May 1, 2007 Share Posted May 1, 2007 Hi all, Thanks for the replies, and I've found the problem! It was a water piper with a hole in it, obviously over time the hose has started to perish. Because of the positioning of the hose (and the hole), the steam was making its' way under the plug cover and out through the vents. Will hopefully track down some black water hose tommorrow Thanks again all for the replies, you're never alone in this place! Jez hmmm... I'm sure I said that... see post #2 Link to comment Share on other sites More sharing options...
rovervi Posted May 1, 2007 Share Posted May 1, 2007 hmmm... I'm sure I said that... see post #2 yeh yeh we know your're always right Link to comment Share on other sites More sharing options...
flukey-lukey Posted May 1, 2007 Share Posted May 1, 2007 yeh yeh we know your're always right damn right! You're right that I'm always right Anyway, I think I should be known as 'the club expert' from now on p.s glad it nothing too serious Link to comment Share on other sites More sharing options...
rovervi Posted May 1, 2007 Share Posted May 1, 2007 damn right! You're right that I'm always right Anyway, I think I should be known as 'the club DRINKING expert' from now on p.s glad it nothing too serious Glad its an easy fix too Link to comment Share on other sites More sharing options...
flukey-lukey Posted May 1, 2007 Share Posted May 1, 2007 Git lol anyway, bedtime... goodnight Link to comment Share on other sites More sharing options...
rovervi Posted May 1, 2007 Share Posted May 1, 2007 Git lol anyway, bedtime... goodnight Link to comment Share on other sites More sharing options...
Dave Posted May 1, 2007 Share Posted May 1, 2007 hmmm... I'm sure I said that... see post #2 i said that too Link to comment Share on other sites More sharing options...
2jzhead Posted May 2, 2007 Share Posted May 2, 2007 The rocker cover gasket might be leaking and it might be leaking oil into the spark plug holes, this happend on our old mkiii Link to comment Share on other sites More sharing options...
