Gaz Walker Posted May 1, 2007 Share Posted May 1, 2007 Hi guys, Club member kslb has asked me to start a thread to detail his project since he's 250 miles away and can't exactly pop in! So here it is! 1998 Black VVTi 6 Speed Supra Before http://www.envyperformance.com/images/projects/keith/before/front.jpg http://www.envyperformance.com/images/projects/keith/before/side.jpg http://www.envyperformance.com/images/projects/keith/before/engine.jpg http://www.envyperformance.com/images/projects/keith/before/interior.jpg http://www.envyperformance.com/images/projects/keith/before/interior2.jpg http://www.envyperformance.com/images/projects/keith/before/wheel.jpg Parts http://www.envyperformance.com/images/projects/keith/before/fmicpanel.jpg http://www.envyperformance.com/images/projects/keith/before/fuelsystem.jpg http://www.envyperformance.com/images/projects/keith/before/manifold.jpg http://www.envyperformance.com/images/projects/keith/before/sparkcover.jpg Link to comment Share on other sites More sharing options...
Alex Posted May 1, 2007 Share Posted May 1, 2007 What ECU are you going to use? Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 1, 2007 Author Share Posted May 1, 2007 http://www.envyperformance.com/images/projects/keith/before/turbo1.jpg http://www.envyperformance.com/images/projects/keith/before/turbo2.jpg http://www.envyperformance.com/images/projects/keith/before/turbo.jpg http://www.envyperformance.com/images/projects/keith/before/turbokit1.jpg http://www.envyperformance.com/images/projects/keith/before/turbokit2.jpg http://www.envyperformance.com/images/projects/keith/before/turbokit3.jpg http://www.envyperformance.com/images/projects/keith/before/turbokit4.jpg http://www.envyperformance.com/images/projects/keith/before/turbokit5.jpg http://www.envyperformance.com/images/projects/keith/before/wastegate.jpg Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 1, 2007 Author Share Posted May 1, 2007 Alex said: What ECU are you going to use? Give me a chance Alex Parts List AEM ECU, IAT/3.5 Bar Map with VVTi control - Mapping by Dan AEM Wideband Gauge HKS DLi Racelogic Kit with Digital Adjuster PHR Stage 2+ Turbo Kit PHR Stage 2 Fuel Kit RPS Max Clutch Envy Modified Breather System Various Engine Dress/Shiney Bits! Volk Racing SF Challenge Wheels in Diamond Black Regards, Gaz. Link to comment Share on other sites More sharing options...
neil tt Posted May 1, 2007 Share Posted May 1, 2007 Lots of very nice pieces there:) Link to comment Share on other sites More sharing options...
dandan Posted May 2, 2007 Share Posted May 2, 2007 Looking good, Stage 2+ mmmmmmmmm Gaz - how would you compare the PHR kit to an SP equivalent for completeness and quality. If that's a bit of a political question then don't worry about answering. It is a genuine question as I know nothing of the SP kits but know how good the PHR ones are. Link to comment Share on other sites More sharing options...
Nic Posted May 2, 2007 Share Posted May 2, 2007 Gaz is that a PHR IC pipe? Just a heads up, I had problems with mine fouling the steering rack, (not a problem on LHD), had to get the pipe cut and welded to fit. Do you have spec and pics of the Envy Breather Kit you could post up. Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 2, 2007 Author Share Posted May 2, 2007 dandan said: Gaz - how would you compare the PHR kit to an SP equivalent for completeness and quality. If that's a bit of a political question then don't worry about answering. It is a genuine question as I know nothing of the SP kits but know how good the PHR ones are. SP now make kits to order, using whatever bits you want - so theres not really an off the shelf kit as such. The SP and PHR kits are very similar, the PHR kits are more expensive but they do use more higher quality components so you can see where the money goes. Nic said: Gaz is that a PHR IC pipe? Just a heads up, I had problems with mine fouling the steering rack, (not a problem on LHD), had to get the pipe cut and welded to fit. Do you have spec and pics of the Envy Breather Kit you could post up. It will be yeah. I never expect anything to fit out of the box so it shouldn't be too much of a problem The Envy breather kit is basically as fitted to our car, I'll try and fit a pic and post up. Regards, Gaz. Link to comment Share on other sites More sharing options...
Mas Posted May 2, 2007 Share Posted May 2, 2007 Gaz, am I seeing a FMIC plate there in one of the pics? is that the ones you were selling for £40 last week/s ? Link to comment Share on other sites More sharing options...
kslb Posted May 2, 2007 Share Posted May 2, 2007 Mas said: Gaz, am I seeing a FMIC plate there in one of the pics? is that the ones you were selling for £40 last week/s ? Its a PHR one. Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 2, 2007 Author Share Posted May 2, 2007 Mas said: Gaz, am I seeing a FMIC plate there in one of the pics? is that the ones you were selling for £40 last week/s ? Its an FMIC plate, but its not one of ours. Keith bought that from PHR, its more expensive than ours... Gaz. Link to comment Share on other sites More sharing options...
Mas Posted May 2, 2007 Share Posted May 2, 2007 Gaz Walker said: Its an FMIC plate, but its not one of ours. Keith bought that from PHR, its more expensive than ours... Gaz. Link to comment Share on other sites More sharing options...
Supradoopa Posted May 2, 2007 Share Posted May 2, 2007 Gaz Walker said: Hi guys, Club member kslb has asked me to start a thread to detail his project since he's 250 miles away and can't exactly pop in! So here it is! 1998 Black VVTi 6 Speed Supra Pffft only 250 miles Link to comment Share on other sites More sharing options...
kslb Posted May 2, 2007 Share Posted May 2, 2007 Supradoopa said: Pffft only 250 miles If I was travelling down and back in the supe it would be a pleasure but not in the Surf, would be a bit boring. Where abouts are you not inverness direction seems to be a few supes there. Link to comment Share on other sites More sharing options...
AlanM Posted May 2, 2007 Share Posted May 2, 2007 250 miles is nothing, you an borrow my bike Link to comment Share on other sites More sharing options...
kslb Posted May 2, 2007 Share Posted May 2, 2007 AlanM said: 250 miles is nothing, you an borrow my bike Tell me it has an engine and I will. Link to comment Share on other sites More sharing options...
Supradoopa Posted May 3, 2007 Share Posted May 3, 2007 kslb said: Tell me it has an engine and I will. kslb said: If I was travelling down and back in the supe it would be a pleasure but not in the Surf, would be a bit boring. Where abouts are you not inverness direction seems to be a few supes there. Yeah im at Kinloss at the min, it's a trek to Envy but always good... not for my wallet though Link to comment Share on other sites More sharing options...
kslb Posted May 3, 2007 Share Posted May 3, 2007 Supradoopa said: Yeah im at Kinloss at the min, it's a trek to Envy but always good... not for my wallet though There is a few from that way coming down for the Aberdeen meet take it you are still heading down as well. Can't wait to see a few supes in the one place not many local meets that I can find hence suggesting this one. Gaz, Any more photos or updates, looking forward to viewing the progress. Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 3, 2007 Author Share Posted May 3, 2007 http://www.envyperformance.com/images/projects/keith/strip1.jpg http://www.envyperformance.com/images/projects/keith/strip2.jpg http://www.envyperformance.com/images/projects/keith/strip3.jpg Link to comment Share on other sites More sharing options...
kslb Posted May 3, 2007 Share Posted May 3, 2007 Looking good, that HKS fuel rail looks good can't believe I am replacing it already its only been on for a 1000 miles. Oh well shiny is the way ahead I suppose. Thanks Gaz. Link to comment Share on other sites More sharing options...
Supradoopa Posted May 3, 2007 Share Posted May 3, 2007 kslb said: There is a few from that way coming down for the Aberdeen meet take it you are still heading down as well. Can't wait to see a few supes in the one place not many local meets that I can find hence suggesting this one. Gaz, Any more photos or updates, looking forward to viewing the progress. I'm on the list to come down but apparently i'm off to the Falklands soon for a few wk so not sure if i'll be back in time. I find out for definate on tues The set-up is looking good can't wait to see more photos Link to comment Share on other sites More sharing options...
dandan Posted May 3, 2007 Share Posted May 3, 2007 Gaz Walker said: SP now make kits to order, using whatever bits you want - so theres not really an off the shelf kit as such. The SP and PHR kits are very similar, the PHR kits are more expensive but they do use more higher quality components so you can see where the money goes. Thanks Gaz - I am looking and kits right now but have no plans to buy one this summer. Maybe a winter project and I'm just weighing up my options right now. Thanks and keep up the good work. Link to comment Share on other sites More sharing options...
kslb Posted May 3, 2007 Share Posted May 3, 2007 Supradoopa said: I'm on the list to come down but apparently i'm off to the Falklands soon for a few wk so not sure if i'll be back in time. I find out for definate on tues The set-up is looking good can't wait to see more photos Hope you make it back in time looking forward to meeting you all. Why the falklands??? Link to comment Share on other sites More sharing options...
Supradoopa Posted May 5, 2007 Share Posted May 5, 2007 Covering the 25th anniversary Link to comment Share on other sites More sharing options...
kslb Posted May 8, 2007 Share Posted May 8, 2007 Gaz is there any more updates, been away for the weekend to the Army Navy rugby,(ARMY WON) just back so thought i would catch up. Cheers Link to comment Share on other sites More sharing options...
