Measuring Oil Temp (sensor location)
M4RK RZ
Sandwich plate is the easiest way, but you will see hotter temps due to the location, best most stable place is the sump but you would need to take it off and weld in a bung.
Ive got mine fitted in a sandwich plate & like you said getting hotter readings there mine's is around 95 degrees normal & goes up to around 115 - 119 when driven hard take it much more correct reading if tapped into sump plug
Just wondered if known what sort of temperatures should one expect being fitted in sandwich plate between oil filter & block so that i can set my saftey limit ????????
You can get a sandwich plate for less than £30 on Ebay.
Or get a tapped sump plug bolt, some here. I cannot remember the size.
http://www.blitz-uk.co.uk/Product-25.aspx
I fitted the sandwich plate , it's a little fiddly getting it tightened up. I bought a deeper socket to do this. There aren't that many threads for holding the oil filter in place either.
If I had to do it again I would put it in the sump.
It's all relative, whatever you get when the car is running well is normal.
Unless you fit a gauge and get a reading from a badly running car, which isn't that probable.
I get around 100c up to about the same as you when giving it some, from previous experience on other cars you should see around 10c drop if fitted to the sump, i might even get a sump plug adapter and stick a thermocouple in just to check the difference;)
I have a bung in the sump and the defi sendor is located there, I see temps of 80-90c normal driving and 100c when pushed ;)
I have a sensor in the filter sandwich plate location and I see 80-90degC normal and 105degC when driving hard. Hmmm.
-Ian
Hit wrong quote! should have been this one, Doh!
I have a Blitz MD Oil Temp gauge in my car, the sensor for mine is in the sump plug.
I replaced the stock sump plug with a tapped 1/8"NPT Female to M12*1.25 Male.
It cost me £5.99 from LMA Group (Part No: LMA086).
:: http://www.lma-group.com/motorsport/Products/Gauge_Fitting_Parts/gauge_fitting_parts.html
Thats usefull info, don't know what the Blitz fitting is like? any problems with clearance, i use Reline gauge and thermocouples and they project about 3/4 to 1" so i'm not sure, don't want the risk of knocking the end off and bleeding the car to death:(
-Ian
To be fair I spend alot of time in traffic with no air flow through cooler !!
Just about to upgrade to fluidyne rad, 4 row intercooler for the same reason !
I had more like 25deg difference when mine was in the sump. I've had it in a sandwich plate, in the sump and now it's where the oil feed for the 2nd turbo would normally be. Not much difference between there and the sandwich plate location.
I have no clearance issues, I'll take a picture in a bit and upload it so you can see.
Here are 3 pics...had to manipulate the brightness in Photoshop as they came out pretty dark on my camera :(
Hopefully you can see enough. Basically, if you look at the 3rd picture where I hold the camera just lower than the engine tray and sump, you'll see that the sensor is not lower than the sump and cannot be seen...so shouldnt be much chance of catching it *touches wood*
The bronze that you can see in the 1st pic close-up is the LMA sump plug I have, the sensor sticks out about 1 inch from it but has a very flexible wire with a spring on it which is now "u" shaped to aid clearance.
