carl0s Posted August 27, 2004 Share Posted August 27, 2004 I like my stock exhaust. I sounds nice, but I want it a little bit more aggressive sometimes, not bad-boy though. I also want more power. It has been suggested that de-catting will have no benefit with a stock exhaust. Is this a defo? Surely there will still be gains? Chris? Would it be a bastard for me to fit the de-cat pipe myself, being a cheapskate? I'd probably only do the number-1 CAT to begin with. Link to comment Share on other sites More sharing options...
Jake Posted August 27, 2004 Share Posted August 27, 2004 The first cat (the one nearest the engine) would be difficult to do yourself. It's not easy to get at and the manifold nuts get really rusty because they are exposed to a lot of heat. I guess that's why a lot of folks do the second cat first. I'm sure you'd see a nice boost in performance even with the standard exhaust.. Link to comment Share on other sites More sharing options...
carl0s Posted August 27, 2004 Author Share Posted August 27, 2004 excellent, thanks. I wonder how much Chris would charge to fit it then...? (the first one, that's the one I want to do) Link to comment Share on other sites More sharing options...
Jake Posted August 27, 2004 Share Posted August 27, 2004 The guys at your local exhaust centre (KwikFit or whatever) would probably do it for a drink, say a tenner. I always go there for the kind of things where you don't need any particular skill - just the right equipment. Link to comment Share on other sites More sharing options...
merckx Posted August 27, 2004 Share Posted August 27, 2004 Would it be a bastard for me to fit the de-cat pipe myself, being a cheapskate? I'd probably only do the number-1 CAT to begin with Definately! The first cat can be a pain! Not easy to get to the nuts, you have to use a long extension with the wrench. I replaced both cats myself last week, 2 nuts were tight but came loose okay. The third one was a right b**tard, the socket rounded off the corners and I had to go out and buy a nut splitter then bash on another socket to remove it. Normally a damaged nut isn't a problem but it is in such an awkward place. On the older cars when undoing the nuts you run the risk of shearing off the studs, you would then have to remove the turbo elbow! If eveything comes loose okay then it is an easy job but if you run into problems you'll wish you paid someone else to do it! Link to comment Share on other sites More sharing options...
Sharpie Posted August 27, 2004 Share Posted August 27, 2004 I don't think you would see/feel much, if any, gain really. IMO I pulled both cats and fitted CW's decats and a Hiper and moved from 0.8 bar to 0.9 bar on my UK Auto. The car felt much better then You could always move to a quiet type exhaust, stock sounding ish but, a little bit more Grr and loose a cat ? Link to comment Share on other sites More sharing options...
Barney Posted August 29, 2004 Share Posted August 29, 2004 Always wise, before you start, to get a set of new studs if you are going to tackle taking out the first cat. Link to comment Share on other sites More sharing options...
dude Posted August 29, 2004 Share Posted August 29, 2004 Originally posted by Barney Always wise, before you start, to get a set of new studs if you are going to tackle taking out the first cat. I now find more snap than come out clean and thats even when using the Hot Spanner on them , they allways crack off fine but 'freeze' a short way down the thread !!!!!! Dude:flame Dev Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 29, 2004 Share Posted August 29, 2004 Originally posted by dude I now find more snap than come out clean and thats even when using the Hot Spanner on them , they allways crack off fine but 'freeze' a short way down the thread !!!!!! Dude:flame Dev Too true Dude! The ones that look brand new and factory fresh often seize, yet the mankiest ones often undo with no problem. I now keep the correct helicoil kit and inserts to hand with new studs and nuts, and a proper stud extractor. Even with all the right gear they can be a Royal PITA. BTW Dude, who makes GOOD double sided tape for fitting body kits? I took a side sill extension off my car to have a look underneath and now want to re attach it. My local factors only sell Pearl brand generic double sided tape, and it's not very thick, nor very sticky. I suspect I should get something better, 3M maybe? Cheers Dude! Link to comment Share on other sites More sharing options...
Jake Posted August 29, 2004 Share Posted August 29, 2004 Chris, Are helicoils really necessary? If space allows, I've always drilled out snapped exhaust manifold studs and retapped them with the next size up (coarse) thread. It's no picnic but it's a lot easier than helicoils :shudder: DISCLAIMER: I'm aware that the aforementioned CW method is undoubtably the more professional method Link to comment Share on other sites More sharing options...
Syed Shah Posted August 30, 2004 Share Posted August 30, 2004 Regarding power and sound, My car went from stock to full decat with stock exhaust. It was slightly louder with a bit more power, but not much. The real gain came from the exhaust. They work best together. Link to comment Share on other sites More sharing options...
carl0s Posted August 30, 2004 Author Share Posted August 30, 2004 okie dokie. I really wish there was a resource of mp3's or .wav's of different exhausts on MK4's. On the one hand I love the sound of a Diablo, and I love the helicopter like hum of an idling Ferrari 575, but on the other I want to remain slightly conspicuous most of the time. Do the words subtle and Supra have any kind of meeting, anywhere? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 30, 2004 Share Posted August 30, 2004 Originally posted by Jake Chris, Are helicoils really necessary? If space allows, I've always drilled out snapped exhaust manifold studs and retapped them with the next size up (coarse) thread. It's no picnic but it's a lot easier than helicoils :shudder: Can't see why that is easier than helicoiling back to a stock size stud? A properly inserted helicoil is stronger than a basic thread in the parent meta. Rolls Royce used to helicoil every important thread in alloy castings, just to give a thread that could take more torque. Helicoils are really easy to use, unlike the (better) Keen Serts. DISCLAIMER: I'm aware that the aforementioned CW method is undoubtably the more professional method Link to comment Share on other sites More sharing options...
