Eve Posted April 29, 2007 Share Posted April 29, 2007 I am very excited having just bought my Supra after dreaming about it for 6 YEARS. Finally old enough for the insurance to be resonable. Two questions; I was test driving and dropped into second instead of fourth (which I meant to) and it red lined; mine is the 1994 RZ TT, J-Spec, does it not have a rev limiter or has this been removed? Also, SPOLIER DOWN button on the dash. Spolier looks pretty fixed to me so this button doesn't appear to do anything unless it is adjusting something under the car?! I know I have a lot to learn! Thanks E Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted April 29, 2007 Share Posted April 29, 2007 Button's probably just filling the hole. What speed were you doing when you meant to drop it 3 gears? Link to comment Share on other sites More sharing options...
Eve Posted April 29, 2007 Author Share Posted April 29, 2007 100kph ish Link to comment Share on other sites More sharing options...
Jake Posted April 29, 2007 Share Posted April 29, 2007 I think you've misunderstood what a rev limiter is for. Whacking it into a really low gear at speed will rev the arse of any car. Link to comment Share on other sites More sharing options...
Solid Snake Posted April 29, 2007 Share Posted April 29, 2007 I am very excited having just bought my Supra after dreaming about it for 6 YEARS. Finally old enough for the insurance to be resonable. Two questions; I was test driving and dropped into second instead of fourth (which I meant to) and it red lined; mine is the 1994 RZ TT, J-Spec, does it not have a rev limiter or has this been removed? Also, SPOLIER DOWN button on the dash. Spolier looks pretty fixed to me so this button doesn't appear to do anything unless it is adjusting something under the car?! I know I have a lot to learn! Thanks E You do realise it`s the FRONT spoiler and not the rear don`t you Link to comment Share on other sites More sharing options...
Jake Posted April 30, 2007 Share Posted April 30, 2007 You do realise it`s the FRONT spoiler and not the rear don`t you O M G I hadn't thought of that! Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted April 30, 2007 Share Posted April 30, 2007 You do realise it`s the FRONT spoiler and not the rear don`t you Oh you CANNOT be serious..... Link to comment Share on other sites More sharing options...
Eve Posted April 30, 2007 Author Share Posted April 30, 2007 I did ponder whether it was the front spoiler.... Link to comment Share on other sites More sharing options...
Stonkin Posted April 30, 2007 Share Posted April 30, 2007 If you have a look in my garage mate, you will see a pic of the front spoiler down. Its just a piece of rubber that helps air flow at speed, and makes the front look, 'fuller' It normally comes down by itself if you go over 60mph and folds back up when you go below 45 ish. When parked up with key in ignition position 2 you can press spoiler down to leave it down whilst parked up. Link to comment Share on other sites More sharing options...
ivan Posted April 30, 2007 Share Posted April 30, 2007 It normally comes down by itself if you go over 60mph and folds back up when you go below 45 ish. When parked up with key in ignition position 2 you can press spoiler down to leave it down whilst parked up.I found out the other day that you can then turn the ignition off and remove the key leaving the spoiler down for those "pose occasions" too. Link to comment Share on other sites More sharing options...
Stonkin Posted April 30, 2007 Share Posted April 30, 2007 yes, you certainly can Ivan looks much better to Link to comment Share on other sites More sharing options...
Lucifer Posted April 30, 2007 Share Posted April 30, 2007 yes, you certainly can Ivan looks much better to Or just pull the fuse when its down and its down forever! Link to comment Share on other sites More sharing options...
Solid Snake Posted April 30, 2007 Share Posted April 30, 2007 Oh you CANNOT be serious..... Is that me or Eve Link to comment Share on other sites More sharing options...
Thorin Posted April 30, 2007 Share Posted April 30, 2007 Or just pull the fuse when its down and its down forever! Don't you get a warning light then though? I forget to be honest, don't even know which fuse either. Link to comment Share on other sites More sharing options...
Greenauto Posted April 30, 2007 Share Posted April 30, 2007 I did ponder whether it was the front spoiler.... Haha did you provide a Hovis picture when they asked for one Eve? just kiddin Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted April 30, 2007 Share Posted April 30, 2007 Is that me or Eve It was the possibility that the rear spoiler was being expected to move. Link to comment Share on other sites More sharing options...
Solid Snake Posted April 30, 2007 Share Posted April 30, 2007 It was the possibility that the rear spoiler was being expected to move. Yeah....I was guessing that Eve thought the rear retracted a la the GTO etc. etc. Link to comment Share on other sites More sharing options...
