Misc Bits and pieces - Stupid cheap
Lucifer
These items are still available as of Today (Tuesday)
All Brand new in Boxes unless stated otherwise. All are Plus delivery.
All items are now at my house so delivery will be next day via post office.
Goodridge Braided Steel Brake Lines - £40
Clear Facelift Front Indicators with Bulbs - £40
K&N Panel Filter for Stock airbox - £40
Stock Air filter (non genuine) - £10
Passenger airbog Triple Gauge pods (like border)- £50
Race logic Analog Controller - £20
Used Greddy BOV - £20
Brake pads Genuine Toyota UK Spec rear pads - £25 Set
Brake pads Standard J-spec non genuine Front £20 set
Ferrea Inlet valves (12) - £50 - stock size
Manual transmission ECU - Used - £50
Auto Transmission ECU - used - £15
Active Spoiler ECU - £20
ABS ECU - £20
Used and very Curbed (but straight) UK 17" wheel Front - £20
Genuine Toyota Water pump £80
Powerflex Bushings Front Upper arm (both front arms) £25
Powerflex Bushings Rear TCA outer (both front arms) £25
POwer flexRear Antiroll bar Bushings £15
Cusco Antiroll bar (front) with bushings £100
  • Replies 91
Is the 3 gauge dash pod the one that runs down the side of your dash or the one that replaces the glovebox?If it's the first option I'll have it please.
I have both so YOu can have the dash one. Please not the is an original border one - it is the one I used for the mould for when I copied them. Its a perfect condition apart from some plaster still on teh inside.
Sold to you sir.
This topic is now closed to further replies.
