robin Posted April 28, 2007 Share Posted April 28, 2007 Only bought the supra on sunday but one of the headlights was full of condensation. I took both headlights out and dried the watery one out then sealed them both with silicone sealant. Looks alot better then having a one nasty misty light. I still have a bit of a problem though. The side/headlight that is closest to the edge of the car wont work. I know the bulbs are ok as I just put new ones in and i know theyre getting power. Shows 11.9 V on my multimeter on the connector but still no light. Anyone know if its possible or easy to get a new plastic twisty bit?? i think mine must be busted. Link to comment Share on other sites More sharing options...
Fifty Posted April 28, 2007 Share Posted April 28, 2007 fog light? switch is rotary on the headlamp stalk Rich Link to comment Share on other sites More sharing options...
robin Posted April 28, 2007 Author Share Posted April 28, 2007 I did wonder if the switch or fuse was dodgey which is why I did the test with teh voltmeter. The clip/plug which goes into the bulb bracket is definately getting power... just seems odd they would both have a loose wire after that point. Both bulbs are brand new too. I will have to test each wire and see where the break is. Can you get new plasitc bits or would it have to be a whole new headlight? I need an EPC... Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted May 9, 2007 Share Posted May 9, 2007 Are you sure you've turned them on? I hadn't realised that there were two twisty bits on the right hand stalk... Link to comment Share on other sites More sharing options...
