Silver front indicator bulbs
merckx
Just bought some silvitac (silver but flash orange) indicator bulbs not realising that they are far too small. When you look at the pics on the net you cannot get any idea of the scale.
The original bulb (about 22mm dia) is on the left , the silvatec on the right.
Bulbs
Anyone know if you can get them the same size as the original bulb?
I did make an adapter but the small silvatec bulbs aren't bright enough.
Not a bad photo considering I used a brand new digital camera that only cost £10.
The original bulb wasn't blown, I just prefer not to have the orange look.
I've also got the facelift lights.
The bulb is clear and fits inside an orange sleeve in the front indicator, I was going to remove this orange sleeve and fit one of these silver looking bulbs instead.
Not sure if you can get them in this size, I've searched everywhere on the net. I can only find ones the same size that I've just bought.
Cannot see any that fit, they must be the push-in type.
I can only see the same ones that I bought (about 8mm dia)- BU501S , I think these are for the indicators on the side of the car and not the front.
They need to be the push in type and about 22mm dia.
The stock bulb holders are the bayonet type aren't they? Phillips do silver bayonet type bulbs. You just need to re-use the stock holders and make the holes bigger in your new facelifts indicator housings to accept the Phillips ones.
http://www.autobulbsdirect.co.uk/ind_philips.htm
I got mine from Silver Fusion but they said they weren't doing any more when the current stock went.
I've got the facelift lights, they don't use the bayonet type.
They're the wedge type that push in.
Bloody stupid of Toyota to use these bulbs, why couldn't they design the lights to accept the univeral bayonet type like most manufacturers use.
I've done loads of searches on the net and I cannot find any wedge type bulbs of the correct size to fit the front indicators(only found the tiny ones that fit the indicator on the side of the car).
I know I could get replacements at Toyota but I want the silver bulbs.
Just try to get hold of some 1994 spec bayonet bulb holders and make the holes bigger in the facelift indicator housing. This is what I'm going to have to do when my Silver Fusion bulbs blow.
