Which DE-CAT to replace
suprababy
Hi
got a U.K Spec TT, at min it has stock exhaust with both cats still in. Just for now i just want to replace one of the cats. Which one would be the better to replace i.e giving better gains etc. Also will removing the first cat enable it to pass Mot or will it only pass with removing 2nd cat?
Thanks
Just replaced both of mine last week:nana:
I would replace the first catalyst as it is more restrictive, it should pass the MOT with either catayst still on the car.
Not sure what it will be like with the standard exhaust though?
If you do a search for decat you will get all the info you need.
Originally posted by suprababy
Hi
Thanks
Definitely the first one, nearest the engine. It's the most restrictive. I am looking at 4 in stock now.... ;)
