Dave F Posted August 25, 2004 Share Posted August 25, 2004 I have a problem with a noisy front end!!!! The front suspension seems to knock when on rough roads and when going over speed bumps it tends to creak. A car dealer once told me this is common for supras but he also told me an GZ was a non turbo!! so I thought I would ask on the forum. (It just passed an mot and they did nt find anything wrong) Quote Link to comment Share on other sites More sharing options...
tbourner Posted August 25, 2004 Share Posted August 25, 2004 Mine creaks over speed bumps too. Dude said it was loose chassis bolts or something! Quote Link to comment Share on other sites More sharing options...
Dave F Posted August 25, 2004 Author Share Posted August 25, 2004 should this have been picked up at the MOT and can anybody tell me what bolts to tighten. (p.s. Why do I have must pay now under my username) Quote Link to comment Share on other sites More sharing options...
Terminator Posted August 25, 2004 Share Posted August 25, 2004 You get so many free post then have to pay a £10 to join up with unlimited rights. Could be your shocks For torque settings on the chassis bolts checkout he manual section on MKIV.com. If your car has had any bolts undone on the suspension whilst on a jack and then retightened while still in the air the bushes could be under excessive load causing the creaking. I had this when I got my car. Find some packing pieces to put under the front lower arm to simulate normal ride height. Jack up the car remove the wheels lower on to the packing and loosen and re-torque the top arm retaining bolt. That is a good suspect. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 25, 2004 Share Posted August 25, 2004 No there are a number of bolts on the front end on older cars that do work loose. Perform the old search on here and you will find the answer to that question (oh you cant cos AFAIK you have to pay up to use the search facility) You could always await one of the techno guru's wandering past and taking pity on you and telling you the exact bolts that work loose and their correct torque or you could pay your massive fee of a tenner and find out yourself. Quote Link to comment Share on other sites More sharing options...
IceMan Posted August 26, 2004 Share Posted August 26, 2004 I drove mine home "enthusiastically" last night then noticed one corner of suspension (rear-left I think) is now making a metallic creak/scrape sound occasionally instead of the deep low soft rattle that I usually get (that Toyota say is normal...). I wonder how different the Bilstein hard suspension (that I have) sounds to the stock suspension? I also guess it has something to do with having fatter tyres... Ice Quote Link to comment Share on other sites More sharing options...
Terminator Posted August 26, 2004 Share Posted August 26, 2004 There should be no noise. I have new Billies and Ebachs and it is beautifully quiet. The quietest it has been for years. Quote Link to comment Share on other sites More sharing options...
SUPRA2000 Posted August 27, 2004 Share Posted August 27, 2004 Guys mine knocks quite abit on rough roads also when going over ditches the steering wheel doesnt stay still it pulls to the left Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 27, 2004 Share Posted August 27, 2004 Originally posted by SUPRA2000 Guys mine knocks quite abit on rough roads also when going over ditches the steering wheel doesnt stay still it pulls to the left Hmm going over ditch's???? Its not a 4X4 you know Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 27, 2004 Share Posted August 27, 2004 Originally posted by SUPRA2000 Guys mine knocks quite abit on rough roads also when going over ditches the steering wheel doesnt stay still it pulls to the left Bloody farmers..... Quote Link to comment Share on other sites More sharing options...
Terminator Posted August 27, 2004 Share Posted August 27, 2004 Originally posted by SUPRA2000 Guys mine knocks quite a bit on rough roads also when going over ditches the steering wheel doesn’t stay still it pulls to the left Sounds like the shocks are going if you get knocking over rough roads. My stock JDM rears showed no signs of leaking but one had lost the last 11 mm of damping and knocked big time. If you get is a little pull to the left driving over ditches, count your self lucky, most of us would loose the nose and rip the suspension right off :flame Dev Quote Link to comment Share on other sites More sharing options...
IceMan Posted August 27, 2004 Share Posted August 27, 2004 My car always pulls to the left a little. I've had it aligned several times. Part of the problem is possibly that Toyota can't reach the ideal +5.0 degrees caster on mkiv.com's Lance alignment settings (they get 3.something). Ice Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted August 27, 2004 Share Posted August 27, 2004 My front left makes a knocking sound when the suspension having to work over time on our bumpy roads, im sure it these loose nuts but dont have clue where they are lol My front does it slightly but not as bad,so they may be slightly tighter Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 27, 2004 Share Posted August 27, 2004 I'm sure dude posted a diagram of all the bolts affected and their correct torque. If I ind it I will let ya know wsb2 and we can do both of our cars at the same time. Quote Link to comment Share on other sites More sharing options...
Terminator Posted August 27, 2004 Share Posted August 27, 2004 This is the one you need. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted August 28, 2004 Share Posted August 28, 2004 Originally posted by dangerous brain I'm sure dude posted a diagram of all the bolts affected and their correct torque. If I ind it I will let ya know wsb2 and we can do both of our cars at the same time. Deal......ermm we can do yours first yea Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 28, 2004 Share Posted August 28, 2004 You know my policy mate I will never do something or suggest something if I wasn't willing to go first. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted August 28, 2004 Share Posted August 28, 2004 no probs mate, i aint bothered whos goes first we both know how to do up bolts send me a PM of possible day and we can arrange something:thumbs: Quote Link to comment Share on other sites More sharing options...
