cheekymonkey Posted April 27, 2007 Share Posted April 27, 2007 I have ordered gauges and sensors for EGT, AFM and Oil Temp... can this sort of thing be done by a "reasonably competent" home mech, or is it a pro job? I don't have a welder or anything, nor would I want one *grin* James Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted April 27, 2007 Share Posted April 27, 2007 I have to mount my oil temp sensor soon - need to look into this also Quote Link to comment Share on other sites More sharing options...
Ark Posted April 27, 2007 Share Posted April 27, 2007 I have ordered gauges and sensors for EGT, AFM and Oil Temp... can this sort of thing be done by a "reasonably competent" home mech, or is it a pro job? I don't have a welder or anything, nor would I want one *grin* James The oil temp is easiest done with either a sandwich plate (potential for leakage) or a tapped oil sump bolt (good luck finding one - let the rest of us know!!!). Easy job with the right parts though. EGT is a drilling and tapping job. Fine if you've got access to the manifold and the right tools. AFM you're best off using a welded on mounting. In summary, if you're properly prepared, you can do it all yourself. If not, you can make a right pigs ear of it. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 27, 2007 Author Share Posted April 27, 2007 The oil temp is easiest done with either a sandwich plate (potential for leakage) or a tapped oil sump bolt (good luck finding one - let the rest of us know!!!). Easy job with the right parts though. EGT is a drilling and tapping job. Fine if you've got access to the manifold and the right tools. AFM you're best off using a welded on mounting. In summary, if you're properly prepared, you can do it all yourself. If not, you can make a right pigs ear of it. That's good advice, thanks - will probably get somewhere reputable like Turbofit to do this for me, assuming that's the sort of thing they do? Looking forward to doing some mods myself when I am more confident, but these gauges need to go on first really Quote Link to comment Share on other sites More sharing options...
merckx Posted April 27, 2007 Share Posted April 27, 2007 a tapped oil sump bolt (good luck finding one - let the rest of us know Any good, I used a sandwich plate. http://www.blitz-uk.co.uk/Product-25.aspx Quote Link to comment Share on other sites More sharing options...
Ark Posted April 28, 2007 Share Posted April 28, 2007 W**kers!! I phoned Fensport and asked about those only about 2 months ago and they swore blind they didn't exist! I used a Greddy sandwich plate in the end too. Quote Link to comment Share on other sites More sharing options...
