R3DG3CKO ROB Posted April 27, 2007 Share Posted April 27, 2007 I've got a loose bolt under the car which sounds like a can of ball bearings at idle... really annoying, as I'm sure you can imagine... The bolt is one of two which hold the exhaust plate (I think thats what its called) together just after the down pipe. They're very rusty so I've decided to replace both of em... Simple question really, what size nuts and bolts do I need to buy to replace them? The car is a J-Spec NA... anyone know what I'm rambling on about??? Link to comment Share on other sites More sharing options...
jamesmark Posted April 27, 2007 Share Posted April 27, 2007 If by exhaust plate you mean the heat sheild, just take the sheild off. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 27, 2007 Author Share Posted April 27, 2007 No its actually under the car... hard to explain really... I jacked it up and there's a flat plate which joins two straight bits of exhaust together... My mate is suggesting m10 bolts as that's what he used on his MR2? Link to comment Share on other sites More sharing options...
RobSheffield Posted April 27, 2007 Share Posted April 27, 2007 Exhaust flange? Link to comment Share on other sites More sharing options...
