Detailed labelling of engine bay?
AJI
Just done a quick search and couldn't find a comprehensive diagram or picture labelling everything in the engine bay...... do we have one on this forum ?
It would be useful for newbies and even long time owners who are not 100% sure what a certain component is or does.
I've just done this earlier today, just needs all the information on each part - I've also got another 4 pics which are close ups of the four areas of the engine bay.
Ian if you want to pinch the picture be my guest, if you want the rest you can find them in my photobucket album :)
01 - Air Filter
02 -
03 - Air Intake Pipe
04 - VIN Plate
05 - Brake Fluid Reserviour
06 -
07 - Distributor Cap
08 - Throttle Body
09 -
10 -
11 - Charcoal Canister
12 - Diagnostic Port
13 -
14 - Fuse Box
15 - Washer Filler
16 - Power Steering Fluid Reserviour
17 - Battery
18 - Radiator Cap
19 - Cam Cover
20 - Viscous Fan Cover
21 - Horn (one of 3)
Someone needs to fill in the blanks as I'm not sure of the technical names :)
01 - Air Filter
02 -
04 - VIN Plate
06 - Brake servo
08 - Throttle Body
09 -
10 -
13 -
14 - Fuse Box
15 - Washer Filler
17 - Battery
18 - Radiator Cap
19 - Cam Cover
just added number 6
and i think number 9 is the intake plenum and number 10 is the inlet manifold,correct me if im wrong
01 - Air Filter
02 - Ignition pack
04 - VIN Plate
06 - Brake servo
08 - Throttle Body
09 - Air Intake resonance piping
10 - Plenium chamber
13 -
14 - Fuse Box
15 - Washer Filler
17 - Battery
18 - Radiator Cap
19 - Cam Cover
This is exactly the type of thing I was on about.
It will help newbies and existing owners to be more 'intimate' with their engine bay !! ;)
:thanku:
Tis a really good idea indeed and can see it being of benifit for alot of people, not just newbies - I've certainly learnt a lot about what's what in the engine bay just recently from having a small problem with my alternator.
Do you want me to post up the other four pics?
(Just need one for a TT now)
Now the question here is, do you have a stock TT or a modified TT? ;)
Have you got the image without the lines drawn on it? I ask because there are other bits that I think should be marked and also the numbering is a little fuzzy at times, I'd name them on the picture anyway so it's easily referenced with a link to the picture and not the thread.
And a stock TT engine piccy please :)
-Ian
And my take on the list:
01 - Air Filter housing
02 -
03 - Main air Intake Pipe
04 - VIN Plate
06 - Brake servo
07 - Distributor
08 - Throttle Body
09 - Air Intake piping
13 - Igniter pack
14 - Fuse Box
15 - Washer Filler
17 - Battery
18 - Radiator Cap
19 - Spark plug cover
20 - Fan shroud
The igniter pack was mislabelled
No idea what #2 is, is it not something aftermarket like an alarm?
What happened to #15 on the picture ;)
The cam covers are the metal bits either side of the spark plug cover
-Ian
You have PM :)
Nope, the main HT lead is plugged into that so I'm presuming it's what Phoenix One said and go with the "Ignition Pack" - although I see you've put 13 down as the ignition pack. Perhaps you'll see better from the other pics? :)
You wouldn't believe me if I told you :D
I think that was the whole point of the thread, post up pics of the engine bay for people who are new to the cars, at least they'll then have a decent knowledge of where everything is.
I seem to remember a thread a while back which became rather famous "where are the turbos" ;) :D :d
No2 is the ignition coil, no 13 is the ignitor ecu
I must have typed the first one in invisible ink so i'll say it again.:rolleyes:
