Lexus IS 200 (2nd car)
ADD
hmm right ok. is it auto or manual? my friend has one, went to manchester and back on one tank of fuel about 460 miles. thay dont light the world up on the speed factor but are quick enough as a 2nd car in my opnion, has it got full history?things to look out for are
-water pump and buypass 'O' rings leaking,
-shocks leak
-bottom ball joints wear
-strut bars perish
-tyre wear is common (a good geom will sort that)
and the most important is the cambelt and tensioner!!! if thay havnt been done THAY WILL NEED DOING as the bearing wears causing the belt to move forward and fray.
dont be put off buy my list its only the things i would look out for, the parts are cheap and easy to do your self if ya up to it.
add me on msn if you want to chat more about it
hmm right ok. is it auto or manual? my friend has one, went to manchester and back on one tank of fuel about 460 miles. thay dont light the world up on the speed factor but are quick enough as a 2nd car in my opnion, has it got full history?thing to look out for are
-shocks leak
-strut bars perish
and the most important is the cambelt and tensioner!!! if thay havnt been dont THAY WILL NEED DOING as the bearing wears causing the belt to move forward and fray.
Thanks for that mate, its a 6 speed sport and it is having a 85k service tomorrow with 4 new rubbers and brakes replaced all round. he has had problems with shockes on the rear though, but presume they will bring that up on the service.
he only wants 4.5k for it (he is a mate)....see i do have one
is he using lexus parts? only we have had problems with pattern brakes and filters before.
4.5k is a very good price for a sport. if it is slow for you and you dont mind spending £1800 then a TTE supercharger kit would be the way forward. if you want to drive one my friend has a supercharged one. ;)
[email protected]
