Fuel Pressure Reg. Fittings
SimonB
Ok, let's say I want to use an Aeromotive fuel pressure regulator with the stock fuel rail, injectors etc. What fittings would I need? I presume some sort of fitting to go in the fuel rail where the stock regulator is and some sort of fitting to connect it back up to the drain back to the tank. What exactly would I need, where could I get it from and can it in fact it be done easily on a stock rail without taking it off and welding stuff?
Originally posted by Justin
Does it not come as a kit?
My FSE came with the adapter to fit where the stock pressure regulator was fitted (bolt on)
Then just fuel hose and connectors to hook up to the existing fuel lines.
i dont think the aeromotive does come with a kit but i will let you know as i have one on the way from VORTEX. if it doesnt i also would like to know which fittings are needed
Guest Terry S
right we are having adaptors machined for the stock rail, or we do a rail on an exchange basis with a -6 return line and braided hose.
what would i need to fit a -6 return line. just remove existing return,drill and tap to take -6 adaptor?
cheers ...lee
cheers ...lee
You'll need to remove the fuel rail, remove the old pressure reg., then you can either get weld on -6 fittings, or you can tap a thread and get bolt in fittings. I've opted for the bolt in fittings on my car.
HTH
HTH
cheers matt, just been speaking to mig about this:thumbs: .
so you're still running the stock fuel rail with your single? what bhp can the stock rail support? any thoughts on dual feed on the stock rail or is it overkill?
Guest Terry S
We do twin entry stock rails. I had one on the purple car originally that handled 690 bhp (genuine engine dyno BHP) without a problem.
So all you need for the simplest setup is one of these adaptors that will bolt in where the stock one goes, and a couple of bits of fuel hose and connectors. No drilling, tapping or welding needed. Have I got that right?
Guest Terry S
That's it mate
any particular reason why? alot of the american guys had leaking problems with the bolt in fixings, do u think welded would b a safer option?
have you any links to the problems they had on the supraforums? ive managed to get hold of a spare stock rail from CJ this morning so am going to modify it for twin -6 feed and -6 return. i'll have to plug one feed though until the single goes on.
maybe toyota r better engineers than the folk who had leaks :) i think they had problems getting a good thread for the length of the fitting, i cant remember exactly. it could b nasty spilling fuel @50psi on a hot engine. u could always sue toyota if it was their rail, but if it was my own work i'd b bummed. im not saying it cant b done, it's just if i did it i'd weld them mofo's on so i knew for sure there would b no issue. i just wondered if there was a reason not to weld em?
lee, i dont at hand. try a search for "fuel rail"
