woohoo i now have coilovers
Guest mk47
Make sure you take some photos of the install process and do a write up for the Technical section :)
Sounds good i'll see if I can get a digicam and take lots of pics :)
got some tein superstreets today :D will be fitting them tomorrow evening so pics will follow..
and erm, thats it!
What did you have before? If it was stock then this from CW might interest you.
The stock suspension is a coil over set up,
:confused:
I got mine yesturday, would love to see some pics of your install, did you get the upper mounts to?
nah i didnt get the top mounts, so will be using oem ones. did you get them with top mounts?
Yeah but mine for some reason came seperatly from the shock so have to built them up as you are going to have to do
build what up mate? i thought you can just use the existing stock top mounts?
I thin he means that you will have to dismantle your coilovers so you can get the top mounts off then 'Build' the new ones up..
Easy job, but make sure the ride hight is set before they go on the car, makes it so much easier!
Yeah sorry thats what i ment
