Nick Posted August 24, 2004 Share Posted August 24, 2004 This one's really annoying me. I've started getting a squeeky/rattle and I've tracked it down to the headlining. If I push up on the interior light it stops, question is how can I cure it without constantly driving one handed...?! Any ideas how it's attached, i.e. can you pop the light cover off and tighten the screw(s)? Or is it all stuck on and requires the whole lining to be removed? Link to comment Share on other sites More sharing options...
Ian C Posted August 24, 2004 Share Posted August 24, 2004 Try lowering your sunvisors and see if the squeak goes away They can 'stick' to the headlining (don't get smutty) and cause stiction noise. -Ian Link to comment Share on other sites More sharing options...
TazUK Posted August 24, 2004 Share Posted August 24, 2004 Originally posted by Ian C Try lowering your sunvisors and see if the squeak goes away They can 'stick' to the headlining (don't get smutty) and cause stiction noise. -Ian I get that problem, but is there a more permanent solution than just flapping them down? Link to comment Share on other sites More sharing options...
Ian C Posted August 24, 2004 Share Posted August 24, 2004 Yes - you can get adhesive backed black foam strip from vehiclewiringproducts.co.uk, cut a couple of chunks of that off and stick them on the headlining and they cushion the sunvisor, stopping it from sticking to the roof lining -Ian Link to comment Share on other sites More sharing options...
Nick Posted August 25, 2004 Author Share Posted August 25, 2004 Thanks Ian, I'll give that a go tonight and see if that cures it.... Link to comment Share on other sites More sharing options...
