Underworld Posted April 25, 2007 Share Posted April 25, 2007 Im a bit confused (as always ). My body shop is fitting my new do-luck bumper. They phoned me and asked me a load of questions about what they should remove etc... Apparently it still has the active spoiler underneath the current bumper? Also what about undertrays? They mentioned about the new one not having a tray area and the old one having one. Are they 2 seperate things? A tray and a bumper? I cannot see it as I cant get to the body shop so its a bit hard to visualize. Can any one explain plz ? Or is the active spoiler part of the stock undertray? Can I take the one off the old one and put it on the new? *Confused* Quote Link to comment Share on other sites More sharing options...
Mike Posted April 25, 2007 Share Posted April 25, 2007 What bumper did you take off? The stock bumper has a separate undertray... and some aftermarket ones have one built in. Quote Link to comment Share on other sites More sharing options...
colsoop Posted April 25, 2007 Share Posted April 25, 2007 As above, i don't know of an aftermarket bumper that allows you to keep the active spoiler, which also has a specific undertray as part of it. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 25, 2007 Share Posted April 25, 2007 You'll need to remove the active spoiler and motor (you should be able to sell this on). Keep the undertray as it helps direct the flow of air through the rad. Quote Link to comment Share on other sites More sharing options...
Underworld Posted April 25, 2007 Author Share Posted April 25, 2007 As above, i don't know of an aftermarket bumper that allows you to keep the active spoiler, which also has a specific undertray as part of it. I currently have a do-luck on it, and the bodyshop guy rekons Ive got the active spoiler inside. Im hoping the old bumper doesnt have a tray built into it, so that I can use that tray on my new bumper Bit confused as to why the active spoiler is still in there. It would suggest that it still has the stock undertray attached to the active spoiler, and the do-luck bumper sitting on top of that, no? Quote Link to comment Share on other sites More sharing options...
Underworld Posted April 25, 2007 Author Share Posted April 25, 2007 P.s does any one have any pics of all this so i can visualise it? A pic means a thousand words Quote Link to comment Share on other sites More sharing options...
Underworld Posted April 25, 2007 Author Share Posted April 25, 2007 If I remove the active spoiler, can i just do this then remove the ecu after? Or do you need to remove ecu first then the active spoiler. And any tips on locating the ecu? Quote Link to comment Share on other sites More sharing options...
