Guest mk47 Posted April 25, 2007 Share Posted April 25, 2007 ive tried a search but not found what im looking for.. ive been offered a set of brand new superstreets (no top mounts) are they worth it?? over say eibach/bilstein.. and if using the stock top mounts will it cause any major issues in future? Quote Link to comment Share on other sites More sharing options...
Nic Posted April 25, 2007 Share Posted April 25, 2007 ive been offered a set of brand new superstreets (no top mounts) are they worth it?? over say eibach/bilstein.. Only if you want height and damping adjustment and if using the stock top mounts will it cause any major issues in future? No they are fine on stock top mounts. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 25, 2007 Share Posted April 25, 2007 is there any limits with regards to how low you can drop the car? not that i want to drive with the exhaust scraping the ground but its good to know Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 25, 2007 Share Posted April 25, 2007 is there any limits with regards to how low you can drop the car? not that i want to drive with the exhaust scraping the ground but its good to know The max you can go on the Supra is -45mm with the Super Streets. Gaz. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted April 25, 2007 Share Posted April 25, 2007 The max you can go on the Supra is -45mm with the Super Streets. Gaz. which would be very low Quote Link to comment Share on other sites More sharing options...
turbonut Posted April 25, 2007 Share Posted April 25, 2007 which would be very low Low is good..... Quote Link to comment Share on other sites More sharing options...
uk-rich Posted April 25, 2007 Share Posted April 25, 2007 tell that to the kerb at thor Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 25, 2007 Share Posted April 25, 2007 tell that to the kerb at thor oooo i remember that! Quote Link to comment Share on other sites More sharing options...
