lockys96 Posted April 24, 2007 Share Posted April 24, 2007 went to turbofit today, 2 kill 2 birds with 1 stone. came back only killing 1, car was to wide for the ramps, and only just went on turbofits ramps for the exhaust. and i thought ramp height was my main issue. where to now Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted April 24, 2007 Share Posted April 24, 2007 is it too low for fingerlifts mate? Quote Link to comment Share on other sites More sharing options...
jazz1 Posted April 24, 2007 Share Posted April 24, 2007 u need to go somewhere where they have a lifting ramp built in the ground to lift your car up Quote Link to comment Share on other sites More sharing options...
Ric Posted April 24, 2007 Share Posted April 24, 2007 i think the point hes making that he cant get it inbetween the 2 posts for the finger lifts? Quote Link to comment Share on other sites More sharing options...
Jezz Posted April 24, 2007 Share Posted April 24, 2007 I watched Ian squeezing it in between the posts. Think 18 year old virgin, and Ron jeremy and you'l get the idea how tight it was! Quote Link to comment Share on other sites More sharing options...
ivan Posted April 24, 2007 Share Posted April 24, 2007 What's the overall width Si? I can ask in Poole to see if it'll fit there if you like. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted April 25, 2007 Author Share Posted April 25, 2007 2.1m, it has to be drive on ramp for wheel alignment Quote Link to comment Share on other sites More sharing options...
ECK Posted April 25, 2007 Share Posted April 25, 2007 2.1m, it has to be drive on ramp for wheel alignment why cant it be done on the ground? Quote Link to comment Share on other sites More sharing options...
Stevie Boy Posted April 25, 2007 Share Posted April 25, 2007 why cant it be done on the ground? My be a bit tricky reaching the adjustment eccentrics and what not! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 25, 2007 Share Posted April 25, 2007 2.1m, it has to be drive on ramp for wheel alignment It doesn't. Quote Link to comment Share on other sites More sharing options...
ivan Posted April 25, 2007 Share Posted April 25, 2007 It doesn't. A pit would do OK too. I'll pop down this afternoon for you Si. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted April 25, 2007 Author Share Posted April 25, 2007 It doesn't. tell me how then chris Quote Link to comment Share on other sites More sharing options...
dibbleyuk Posted April 25, 2007 Share Posted April 25, 2007 Lets see some pics of this wide car then:Pics: Quote Link to comment Share on other sites More sharing options...
Stevie Boy Posted April 25, 2007 Share Posted April 25, 2007 A pit would do OK too. I'll pop down this afternoon for you Si. Are pits still legal in garages? I thought they were'nt for some reason, noxious gases settling at the bottom and getting mechanics higher then Pete Docherty, i guess an extractor could sort that out. Quote Link to comment Share on other sites More sharing options...
ivan Posted April 25, 2007 Share Posted April 25, 2007 Lets see some pics of this wide car then:Pics: There's a thread around here somewhere. Quote Link to comment Share on other sites More sharing options...
ivan Posted April 25, 2007 Share Posted April 25, 2007 Si, I've just been down and talked to the guys at ProTyre in Poole. They reckon they should just about be able to get it on their alignment ramps with about 1mm to spare each side on the adjustment plates. Bit of a trek, but if all else fails it's an option to explore. They said to bring the settings you need with you. ProTyre are here: http://www.streetmap.co.uk/newmap.srf?x=400390&y=93743&z=1&sv=400390,93743&st=4&ar=Y&mapp=newmap.srf&searchp=newsearch.srf Quote Link to comment Share on other sites More sharing options...
lockys96 Posted April 25, 2007 Author Share Posted April 25, 2007 Si, I've just been down and talked to the guys at ProTyre in Poole. They reckon they should just about be able to get it on their alignment ramps with about 1mm to spare each side on the adjustment plates. Bit of a trek, but if all else fails it's an option to explore. They said to bring the settings you need with you. ProTyre are here: http://www.streetmap.co.uk/newmap.srf?x=400390&y=93743&z=1&sv=400390,93743&st=4&ar=Y&mapp=newmap.srf&searchp=newsearch.srf oh ill have some chips and cheese on the settings, thats not a good sight. i need a speacilist, as the tyres are not sitting flat, due to non-stock wheels. i should be asking them, but thanks all the same Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 16, 2007 Share Posted May 16, 2007 SI where did you take your car, ive just done an oil change and found I need 3 tyres As if my bank balance hasnt had enough this month! Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted May 16, 2007 Share Posted May 16, 2007 seriously, try super tyres in Maldon (01621 840100) I'd be amazed if they can't do it (I've been told, but don't know whether to believe that alot of the Ferrari garages use them!) Quote Link to comment Share on other sites More sharing options...
lockys96 Posted May 16, 2007 Author Share Posted May 16, 2007 thought i pm'd you the address its christchurch tyres Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 16, 2007 Share Posted May 16, 2007 how much did it cost for the alignment? not that it matters too much as seems to be only place that can do it, could you feel an improvement, did they put in their own settings? Just got 2x 255/30/20's for £213 for the pair....over the moon, continentals too. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted May 16, 2007 Author Share Posted May 16, 2007 really, i got 2x toyo 295 35 18 for 150 delivered. lmao yep, i told them they couldnt go by the stock settings, which they understood. yes the steering wheel went so light, which showed how far out it was. £50 plus vat Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 16, 2007 Share Posted May 16, 2007 Bargain!! bet they were looking over the car quite a bit, take it you didnt book but just turned up? Mine is well out, by the way my front tyres have tread on the outside and threads on the inside. safe to say wont be at japfest Quote Link to comment Share on other sites More sharing options...
lockys96 Posted May 16, 2007 Author Share Posted May 16, 2007 nope. i rang to book. they are very busy Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 16, 2007 Share Posted May 16, 2007 ahh ok, well I got to wait for my tyres to turn up yet anyway so thats fine. Quote Link to comment Share on other sites More sharing options...
