Lucas Posted April 24, 2007 Share Posted April 24, 2007 I have this installed and have not idea what it is I also think its connected to the this dial which is not working. It reads this all the time Any help would be great. Link to comment Share on other sites More sharing options...
RobSheffield Posted April 24, 2007 Share Posted April 24, 2007 It is a Greddy boost guage, and controller Maybe it is not connected correctly Link to comment Share on other sites More sharing options...
Lucas Posted April 24, 2007 Author Share Posted April 24, 2007 Looks like a very old controller then as the only way i can see it being configured is with a screw driver where i guess it changes the boost? Link to comment Share on other sites More sharing options...
RobSheffield Posted April 24, 2007 Share Posted April 24, 2007 Sorry, its a controller for the guage, not a 'boost controller' Think of it like a brain for the guage IIRC the adjusters on it adjust the alarms and display peak boost etc. Link to comment Share on other sites More sharing options...
Lucas Posted April 24, 2007 Author Share Posted April 24, 2007 Ah ok mate cheers I have played around with the adjuster and it moves the needle, so I have put it to 0. Still not getting anything else thou so must be something else wrong as the warning light is still on. Link to comment Share on other sites More sharing options...
DamanC Posted April 24, 2007 Share Posted April 24, 2007 boost pipe has probably been disconnected Link to comment Share on other sites More sharing options...
Lucas Posted April 24, 2007 Author Share Posted April 24, 2007 Not traced the pipes yet so will take a look where they are. Cheers Link to comment Share on other sites More sharing options...
kslb Posted April 24, 2007 Share Posted April 24, 2007 I had exactly the same problem with mine and it is as stated the pipe has been disconnected. It just needs the pipe located and refitted mine was hiding on the right side of the drivers footwell behind the panel. It is a bloody good gauge and worth sorting. I looked at replacing it but glad i sorted it. Link to comment Share on other sites More sharing options...
lockys96 Posted April 24, 2007 Share Posted April 24, 2007 mate, try just pushing in the button on the box. Link to comment Share on other sites More sharing options...
Lucas Posted April 25, 2007 Author Share Posted April 25, 2007 Did that mate but when you turn the box off the needle goes right round to the end and sits there. Have had look for a pipe but cant find one. Looks like the dash will have to come out to see what is on the back on the dial. Link to comment Share on other sites More sharing options...
MKIVDreamer Posted April 25, 2007 Share Posted April 25, 2007 It looks like it has memory/peak hold functions which would suggest to me that it is an electronic boost gauge. That would explain your inability to find a vac hose - it will not have one - rather a wire leading to a pressure sensor. This will probably be a (mainly) rectangular shaped black plastic sealed box in the engine bay - it will need to be plumbed in via a vac hose at some point - probably somewhere near the stock pressure sensor? Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted April 25, 2007 Share Posted April 25, 2007 we had look also and could not find it Link to comment Share on other sites More sharing options...
TrickTT Posted April 25, 2007 Share Posted April 25, 2007 The pressure sensor is a small metal cylinder, about the size of the top of your thumb, with a 3mm hose at 1 end and 4 wires at the other. It will probably be tucked away behind the engine, by the bulkhead. Link to comment Share on other sites More sharing options...
Lucas Posted April 25, 2007 Author Share Posted April 25, 2007 Yep you are right. Found the pressure sensor and leading of that was the vac hose going to a T peace witch is all connected. Traced the electrics from the other side of the sensor to a white plug and again connected so still in the dark on this one really. Link to comment Share on other sites More sharing options...
