Scooter Posted August 21, 2004 Share Posted August 21, 2004 just to save me some time, can anyone please tell me if there is a main electrical connector in the car (rather than the door itself) for all the wiring to the doors? ie you unplug this and then a door can be removed? or is it that all the cables inside the door card need to be unclipped and fed back out through the door? Quote Link to comment Share on other sites More sharing options...
Jake Posted August 21, 2004 Share Posted August 21, 2004 I'm sure there's nothing inside the car like that, so the only way would be to undo the wires from inside the door. Should be easy enough though. Quote Link to comment Share on other sites More sharing options...
matt Posted August 21, 2004 Share Posted August 21, 2004 I'm pretty sure the door loom also has connectors at the bottom of the a-pillar. So the choice is yours................ feed them thro' the door, or pull thro' the pillar. Quote Link to comment Share on other sites More sharing options...
Jake Posted August 21, 2004 Share Posted August 21, 2004 Originally posted by matt I'm pretty sure the door loom also has connectors at the bottom of the a-pillar Yeah? I never saw them when I was trying to fit my tweeters. I might be blind though . . . Quote Link to comment Share on other sites More sharing options...
matt Posted August 22, 2004 Share Posted August 22, 2004 Or your hand was in the way? Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 22, 2004 Author Share Posted August 22, 2004 Originally posted by matt Or your hand was in the way? Cheers, i'll have a look around when the time come to seewhat will be easier for me....... Btw 'HOW' heavy is a supra door! nearly gave myself a hernia getting it into the boot of the supra Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted August 22, 2004 Share Posted August 22, 2004 Originally posted by Scooter Btw 'HOW' heavy is a supra door! nearly gave myself a hernia getting it into the boot of the supra You got one into the boot of a soop?? I'm lucky if I can squeeze a plastic bag into my boot. Ben.. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 22, 2004 Share Posted August 22, 2004 Door is soddin heavy because of that massive iron side impact protection bar in it. You can disconnect the wiring harness in the door without removing all the bits through it. Be buggered if I can remember where inside the car it disconnects but it does. Quote Link to comment Share on other sites More sharing options...
