Wires through the firewall
terribleturner
Well i used to run my wires through the clutch hole in the Firewall, but now im 6 speed i don't have this option. As i have by turbo and manifold out of the car would it be a bad idea to just drill a hole in it to feed wires through?? If not is there somewhere apart from the wing that im missing??
I had this problem when i went 6 speed but i wasn't prepared to cut and re solder wires.
My clifford installer had used this hole too for a few wires.
I had to file out a "U" shape at the bottom of the hole and put all the wires in the "U" at the bottom. It was a real pain in the arse to fit the clutch reservoir and get all the wires out the way so not to crush them
Worked though ;)
Worked though ;)
Yeah think i'll have to go with that. Just thought i could have got away with a discreet hole for the wires now.
