terribleturner Posted April 22, 2007 Share Posted April 22, 2007 Well i used to run my wires through the clutch hole in the Firewall, but now im 6 speed i don't have this option. As i have by turbo and manifold out of the car would it be a bad idea to just drill a hole in it to feed wires through?? If not is there somewhere apart from the wing that im missing?? Quote Link to comment Share on other sites More sharing options...
Ric Posted April 22, 2007 Share Posted April 22, 2007 theres a big one behind the charcoal canister? Quote Link to comment Share on other sites More sharing options...
terribleturner Posted April 22, 2007 Author Share Posted April 22, 2007 Thanks but i want to go through on the drivers side. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted April 23, 2007 Author Share Posted April 23, 2007 Bump Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted April 23, 2007 Share Posted April 23, 2007 I had this problem when i went 6 speed but i wasn't prepared to cut and re solder wires. My clifford installer had used this hole too for a few wires. I had to file out a "U" shape at the bottom of the hole and put all the wires in the "U" at the bottom. It was a real pain in the arse to fit the clutch reservoir and get all the wires out the way so not to crush them Worked though Quote Link to comment Share on other sites More sharing options...
SupraJames Posted April 23, 2007 Share Posted April 23, 2007 I have a hole in the firewall just above the pedals I use it to feed all the gauge sensors though and being an Auto doubt its a clutch wire hole. Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted April 23, 2007 Share Posted April 23, 2007 thats the hole used for the clutch pedal/cylinder dude. Auto and Manual supras have the same bodys, just a small section of the tunnel welded in is different Quote Link to comment Share on other sites More sharing options...
terribleturner Posted April 23, 2007 Author Share Posted April 23, 2007 I had this problem when i went 6 speed but i wasn't prepared to cut and re solder wires. My clifford installer had used this hole too for a few wires. I had to file out a "U" shape at the bottom of the hole and put all the wires in the "U" at the bottom. It was a real pain in the arse to fit the clutch reservoir and get all the wires out the way so not to crush them Worked though Yeah think i'll have to go with that. Just thought i could have got away with a discreet hole for the wires now. Quote Link to comment Share on other sites More sharing options...
