Guest chris b Posted April 20, 2007 Share Posted April 20, 2007 Hi there i wonder if someone can shed some light on the problem with my import TT. My car cuts out at 115mph now i take it this is the speed restircter, this has only happened in the last couple of weeks whilst testing it on a private road, never had any problems with it cutting out before. The only thing that I have changed to the car was fitting a new stereo about 2months ago. The car was Hadyns supra K***XTT Quote Link to comment Share on other sites More sharing options...
Paul372 Posted April 21, 2007 Share Posted April 21, 2007 hi, its the speed restircter all jap cars are fitted with one before they come over into this country, you can have it removed i think it costs around about £100 to have it done Quote Link to comment Share on other sites More sharing options...
Guest chris b Posted April 21, 2007 Share Posted April 21, 2007 Never had the restricter problem before so anyone know why its started cutting in recently ? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 21, 2007 Share Posted April 21, 2007 Presumably because there's something wrong with delimiter. Check the wiring to it. Haydn is a notorious tight-wad so he may well have fitted some cheap-ass POS delimiter from eBay or somesuch. Quote Link to comment Share on other sites More sharing options...
hadyn Posted April 22, 2007 Share Posted April 22, 2007 Haydn is a notorious tight-wad so he may well have fitted some cheap-ass POS delimiter from eBay or somesuch. Theres absolutely no need for this comment if it was not meant in good humour Jake. My old car was delimited by using an old skool Apexi RSM. Has the car still got it fitted, does it still work? Id check the wiring from the ECU to the RSM as this may be the culprit Quote Link to comment Share on other sites More sharing options...
hadyn Posted April 22, 2007 Share Posted April 22, 2007 It also could be down to the fact that the RSM has had some of the options on it adjusted. If I remember right, you have to set it to a setting to remove the factory speed limiter. Can anyone clarify this? Quote Link to comment Share on other sites More sharing options...
hadyn Posted April 25, 2007 Share Posted April 25, 2007 You get this sorted chris? Quote Link to comment Share on other sites More sharing options...
