Fargo Posted April 20, 2007 Share Posted April 20, 2007 as the tittle says, will uk spec turbos bolt straight on to a jspec soop. Quote Link to comment Share on other sites More sharing options...
CJ Posted April 20, 2007 Share Posted April 20, 2007 Afraid not old chap. I "think" there are several differences not least a different manifold. Quote Link to comment Share on other sites More sharing options...
Ian W Posted April 20, 2007 Share Posted April 20, 2007 Afraid not old chap. I "think" there are several differences not least a different manifold. hence the use of Hybrids? Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 20, 2007 Share Posted April 20, 2007 Hmmm, I know there are a few differences... They would line up with the head, but the exhaust manifold is different, also they would have a slightly different pressure map which wouldn't suit the stock J-spec ECU. Quote Link to comment Share on other sites More sharing options...
Fargo Posted April 20, 2007 Author Share Posted April 20, 2007 so if a set were to come with actuator and manifold, what else would be needed to put onto the jspec, im thinking more in terms of having the stronger steel blades instead of the ceramic ones Quote Link to comment Share on other sites More sharing options...
Alex Posted April 20, 2007 Share Posted April 20, 2007 Reall you want everything from the manifold to the 1st downpipe...inc everything in between. Quote Link to comment Share on other sites More sharing options...
Jake Posted April 20, 2007 Share Posted April 20, 2007 Why would you want to put those laggy old things on your car anyway? Stick with the fast spooling ceramic ones - much better. Quote Link to comment Share on other sites More sharing options...
Bob Posted April 20, 2007 Share Posted April 20, 2007 Reall you want everything from the manifold to the 1st downpipe...inc everything in between. including the bloody expensive ceramic valvey thing [scientific term] (exhaust gas recirculating valve?) and a blanking plate for one of the exhaust valve bits on the manifold. Quote Link to comment Share on other sites More sharing options...
