Chase Posted August 18, 2004 Share Posted August 18, 2004 Want to get fuelling checked, but having seen various prints from different rolling roads, I've seen a few that don't have the AFR info on them. Am I able to get this info from any dyno/rolling road or are they not all capable of doing this. While I'm at it - does can anyone recommend a dyno in the Manchester area...? I'd really like to get down to Thor, but as I just want a diagnostic run, do I really need to... Cheers Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 18, 2004 Share Posted August 18, 2004 Most/all the dynos I've seen will be able to give you AFR readings. If you want to compare power on a kind of before and after basis, stick to the same one as different dynos tend to give different readings. Sorry, no idea on dynos around Manchester though. Quote Link to comment Share on other sites More sharing options...
tDR Posted August 18, 2004 Share Posted August 18, 2004 Make sure it's a wideband lambda sensor they use! As many RR's seem to use narrowbands which are useless when it comes to tuning. HTH, Brian. Quote Link to comment Share on other sites More sharing options...
