Help with coil pack connectors..
wkdtime
I have got some new connectors from Envy,
I was fitting them, and then realised that with one of the old connectors which was completely shagged both the wires with the pins are out but i have no idea which wire goes into to which end of the new connector:(
if you check the other connectors what colour are the TRACE wires in them? i would of thought thay may help you
They're just brand new connectors bud, no wires attached to them for reference, all the other wires ont he other connectors are different colours too.
Which cyclinder number is it on? If you let me know the colours of the wires you have I'll pop outside and check mine.
Cheers Homer, soz for the late reply just got in,
Its cylinder number 5, assuming number one is the first one as you face the engine.
