Class One Posted April 19, 2007 Share Posted April 19, 2007 I was considering buying some BP 102 ron fuel for Supra Pod on Saturday. There's a BP garage in MK that sells it, so I was thinking of buying 10 litres or so and using/mixing it in with the V power that'll be in my tank on Saturday. Good idea or waste of cash? Link to comment Share on other sites More sharing options...
tooquicktostop Posted April 19, 2007 Share Posted April 19, 2007 I am interested in this also, I have race fuel mapped into the AEM on a switch and never used it, does it make much difference ? Link to comment Share on other sites More sharing options...
ManwithSupra Posted April 19, 2007 Share Posted April 19, 2007 How much is the per litre? Link to comment Share on other sites More sharing options...
Class One Posted April 19, 2007 Author Share Posted April 19, 2007 IIRC about £2.50/litre You can either put into two plastic cans (5 litres each) or two metal jerry cans (10 litres each) or into your car if you have VERY deep pockets. Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 19, 2007 Share Posted April 19, 2007 think itll be a waste of £ for a bpu to be honest. Link to comment Share on other sites More sharing options...
letmeshowyou Posted April 19, 2007 Share Posted April 19, 2007 I use the millers turbo stuff (as it's staved off det for me on hot days) I wouldn't say waster of money - anything that will reduce your chances of det when gunning it has gotta be a good idea. edit: Doug have you got your fcd on yet? Link to comment Share on other sites More sharing options...
tooquicktostop Posted April 19, 2007 Share Posted April 19, 2007 So it would make a difference with a single set up then? Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 19, 2007 Share Posted April 19, 2007 I'll have a couple of drums of C16 in the jeep should anyone want to give that a whirl. 102 is for girls Gaz. Link to comment Share on other sites More sharing options...
Class One Posted April 19, 2007 Author Share Posted April 19, 2007 No. Was hoping that someone could do it for me on Saturday if they have a mo. Link to comment Share on other sites More sharing options...
Wez Posted April 19, 2007 Share Posted April 19, 2007 I'll have a couple of drums of C16 in the jeep should anyone want to give that a whirl. 102 is for girls Gaz. Am i right in saying that this would only be of use to cars with reset stock ECUs and standalones that are mapped for it. If you are running an EM or AEM which has only been mapped on standard fuel then there is no point? Link to comment Share on other sites More sharing options...
Sharpie Posted April 19, 2007 Share Posted April 19, 2007 Will it reduce the life or kill any WB02 sensor ? Link to comment Share on other sites More sharing options...
Wez Posted April 19, 2007 Share Posted April 19, 2007 Depends if its leaded. Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 19, 2007 Share Posted April 19, 2007 Am i right in saying that this would only be of use to cars with reset stock ECUs and standalones that are mapped for it. If you are running an EM or AEM which has only been mapped on standard fuel then there is no point? Technically, yes - however running this fuel on a car not mapped for it would still prevent det, which is rather important! It wouldn't give you that much of a power advantage however, unless you can advance the ignition to make use of it. You could run a touch more boost though Gaz. Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 19, 2007 Share Posted April 19, 2007 Will it reduce the life or kill any WB02 sensor ? Depends if its leaded. C16 is leaded. Running it for one occasion will make little difference to sensors. We've only replaced our AEM WB02 sensor once in the 2.5 years we've been running this for racing! Gaz. Link to comment Share on other sites More sharing options...
supRo Posted April 19, 2007 Share Posted April 19, 2007 I looked at few of the pumps at the BP Garage near Pod and I couldn't see any 102 pumps a month ago. Which MK BP has the 102 fuel? Ta Link to comment Share on other sites More sharing options...
Muffleman Posted April 19, 2007 Share Posted April 19, 2007 I'll have a couple of drums of C16 in the jeep should anyone want to give that a whirl. 102 is for girls Gaz. BP on the way into Newport Pagnell sells it I think, pretty sure they sold it there. Might be dropping off the convoy to visit Turbofit on the way, so might have to go past the Newport BP Link to comment Share on other sites More sharing options...
Guest Geneb Posted April 19, 2007 Share Posted April 19, 2007 £2.50 a litre fook!!!!! you could buy a donna kebab for that!!!!! Link to comment Share on other sites More sharing options...
