Mountain Bikers
Supragal
if i had the cash i'd go for an Orange, however i don't so ended up with a Claud Butler that's gonna be done if i do any serious stuff (not likely since the girlfriend applies the brakes at the slightest downhill).
as of where to buy from, not sure i can help on that as i just went along to my local place in inverness.
Guest Phillw454
I used to use a kona, cant remeber the name right now but was their full sus downhill bike, never let me down but i again have been out of it for 2 years.
Orange are good but pricey for their high spec bikes. Santacruz? Only £3000+:D
  Supragal said:
I had a few cannondales, a GT, Klein, Orange, Identiti.
I used to have a Cannondale M1000 a fair few years ago, kitted it out quite well, then it got nicked, and I discovered beer and fags and kebabs...
  cashpoint said:
Bit off topic but front brake on my bike is leaking so need to top it up (and find the leak at some point too) . As I've got couple of bottles of brake fluid for a car can i use this on a bike?
I'm assuming you're talking about disc brakes using hydraulic fluid. Be VERY careful which fluid you use - make sure it is of the same type (probably DOT 4.1 or 5.1 - I haven't been on my bike for three years :rolleyes:). It'll probably have some note or inscription on the reservoir recommending which fluid to use.
  Supragal said:
dot 5, presuming you're talking about disc brakes?
Correct - from memory most disc brakes for mountain bikes use dot4 or dot5.1 (preferably 5.1 due to boiling temps etc). not to be confused with dot5 (which has a different make-up, but I won't go into a chemistry lecture now).
Yes talking about hydraulic discs.
As for the original question as to what bike. Mine was brought new off fleabay and has stood up to as much punishment (more in fact as i came off alot in at the start of thorwing it down hills) as bikes worth 5 times the price. Even now i don't see why you'd spend over £500 when a well bought £200 bike does everything thats needed.
An expensive bike doesn't make a good rider, while a good rider will make a cheap bike look good.
Good thread i have tbeen thinking about getting back in to it after 5 years away.
i was browsing through a mountain bike mag the other day and god things have changed technology has really come on leaps and bounds.
I have a racing bike for fitness and i get bored doing mile after mile of straight road so could do with a mountain bike as well..
Nothing beats that rush of darting through single track roads skimming between trees and logs. :cool:
Are Gt still up there as one of the best ?
  Supragal said:
I had a Zaskar and it was cool :cool: not anymore apparently :cry:
I almost bought one of those about 6 years ago! They had the interesting frame geometry (like many GTs). In the end I went for an old (1998) stumpjumper (specialized) off ebay. Then I proceeded to get new wheels, brakes, seat post, entire drive train so it almost cost as much as a new one. :rolleyes: But, it looked (and still does) IMHO awesome..................hmmm must go riding. :cool:
go retro and get one of the bikes you remember :)
If you are not after full suspension then nothing much has changed over the years............
A classic Klein or Kona (explosive etc) hardtail would be a good choice...........always fancied an Endorphin myself but they are scarce these days............
