hodge Posted April 17, 2007 Share Posted April 17, 2007 When the cars cold its spluttering when started with trouble ticking over. Once its warmed up abit it sorts itself out and ticks over great sounds spot on. The cars just came back from envy as i had the cylinder head reconed. I did all the head work myself. And the cars ran better than ever for around 3 days then starting to play up again. It took altogether just over 5 months to find out it was the hea that was the problem and get the car back. I knew 31 is map sensor but thats ok and 14 is ignition signal. Any advice. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 23, 2015 Share Posted May 23, 2015 Jon did you ever get to the bottom of this as mine is doing the same as what you have explained ? A kna it's 7 years old but... Lol Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 23, 2015 Share Posted May 23, 2015 Get a garage to `scope the igniter signals. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 23, 2015 Share Posted May 23, 2015 Cheers Chris will do, I've Just pulled each of the coil pack clips off the coils one by one and the 5th one from the front of the car does not change the sound of the misfire all the others do. Are the coil packs interchangeable so I can swap them around to see if it's the plug or the coil pack that nackad Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 23, 2015 Share Posted May 23, 2015 Yes, swap the number 5 coil pairing for another, say the front pair. See if the miss follows the coil. If not swap number 5 spark plug with another. If still no change look at number 5 injector connection. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 23, 2015 Share Posted May 23, 2015 Sorted cheers mate Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 23, 2015 Share Posted May 23, 2015 Thinking what the code 89 from the o/d light was for then? I've cleared the codes so I'll check later after a drive to see if code 89 comes back .. Code 14 now fixed Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted May 23, 2015 Share Posted May 23, 2015 What was it then ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 23, 2015 Share Posted May 23, 2015 Yes, PLEASE always post what the fix was to help others in the future! Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 24, 2015 Share Posted May 24, 2015 What was it then ? Yes, PLEASE always post what the fix was to help others in the future! Sorry lads thought I had posted what it was, It was the actual coil pack clip on the harness visually looked ok but the wires must of been touching. After moving the coil packs like you said Chris the same (5th) clip was still not changing the effect of the engine so I put a new one on. :-) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted May 24, 2015 Share Posted May 24, 2015 Worth doing them all. Then Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 26, 2015 Share Posted May 26, 2015 Worth doing them all. Then Yeah mate I really should of but like a say they did look ok at the time. But for people that do them I would advise to replace all of them. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 To do a proper job you should buy the terminal repair wires as well. Just changing the plastic enclosures will renew the plastic connector shells, but you are still using 20 year old terminals that live in a rather hostile environment. I would recommend you fit repair kits and replace the old connectors as well. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 26, 2015 Share Posted May 26, 2015 To do a proper job you should buy the terminal repair wires as well. Just changing the plastic enclosures will renew the plastic connector shells, but you are still using 20 year old terminals that live in a rather hostile environment. I would recommend you fit repair kits and replace the old connectors as well. That's what I did Chris I bought the full kit off eBay I'm sure it was off a lad on here who sells them. Quote Link to comment Share on other sites More sharing options...
