ultra_supra Posted April 17, 2007 Share Posted April 17, 2007 hi all - does anyone else use one of the above? i have one made by 'Field' and would like to remove it as it was only used in japan & the pervious owner never used it anyway, can anyone tell me whats needed to remove this but without causing problems with the car - fueling etc? or even if theres a garage that can do it? thanks! pics below: Quote Link to comment Share on other sites More sharing options...
Nic Posted April 17, 2007 Share Posted April 17, 2007 Check first of all, what injectors you have fitted, if the injectors are bigger than stock, then you will need some way of controlling the fueling. If they are the stock ones then you should be okay just to remove the thing. Quote Link to comment Share on other sites More sharing options...
