dmx75 Posted April 16, 2007 Share Posted April 16, 2007 Whats the best breaks to have for the TT Supra any 1? And where to get them and how much should they cost? Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted April 16, 2007 Share Posted April 16, 2007 Brembo's are on my wish list. About £3,500 for their big brake set-up. You do get front and rear for that though. Quote Link to comment Share on other sites More sharing options...
dmx75 Posted April 16, 2007 Author Share Posted April 16, 2007 £3,500 bloody hell, thats a little tooo expensive for me, more talking about the normal brakes..lol. Thats on my wish list as well then mate Quote Link to comment Share on other sites More sharing options...
Al Massey Posted April 16, 2007 Share Posted April 16, 2007 you could always go for the uk spec brakes,thats if they fit with your wheels,speak to jezzybabes or other traders for prices Quote Link to comment Share on other sites More sharing options...
SupraPL Posted April 16, 2007 Share Posted April 16, 2007 Best brakes for less than £1k? (front and rear) UK TT? Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted April 16, 2007 Share Posted April 16, 2007 Best brakes for less than £1k? (front and rear) UK TT? lol good luck!! id go for the D2 8 pots for about £1200...there a bargain for what you get and you wont need upgraded back brakes with them! Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted April 16, 2007 Share Posted April 16, 2007 lol good luck!! id go for the D2 8 pots for about £1200...there a bargain for what you get and you wont need upgraded back brakes with them! However to stop to much brake fade under really heavy braking and to stop the back trying to overtake the front when braking around a corner then its advisable to get the rears uprated as well. Quote Link to comment Share on other sites More sharing options...
Guest Rab88 Posted April 16, 2007 Share Posted April 16, 2007 I've got Brembo 14" GTs all round. Excellent brakes although they could be a lot better if the the master cylinder was upgraded. Quote Link to comment Share on other sites More sharing options...
Thorin Posted April 16, 2007 Share Posted April 16, 2007 However to stop to much brake fade under really heavy braking and to stop the front trying to overtake the back when braking around a corner then its advisable to get the rears uprated as well. Absolutely! UK Spec brakes are the best bang for buck. With some good pads, fluid, braided lines, brace master cylinder, etc. you won't need anything else unless you're a track day fiend Stick with OEM discs too, they're cheap enough to consider as disposable and you won't have to worry about cracking them (like with drilled). Quote Link to comment Share on other sites More sharing options...
colsoop Posted April 16, 2007 Share Posted April 16, 2007 Absolutely! UK Spec brakes are the best bang for buck. With some good pads, fluid, braided lines, brace master cylinder, etc. you won't need anything else unless you're a track day fiend Stick with OEM discs too, they're cheap enough to consider as disposable and you won't have to worry about cracking them (like with drilled). I agree, i bet the d2 front brakes on their own wouldn't be any better than front and rear uk brakes. Quote Link to comment Share on other sites More sharing options...
MarkR Posted April 16, 2007 Share Posted April 16, 2007 Guys... I've had custom work done on my Supe... Brembo fronts for a very good price from a friend who works in the industry. PM me for details, and i'll let you know how it works... Quote Link to comment Share on other sites More sharing options...
Nic Posted April 16, 2007 Share Posted April 16, 2007 Absolutely! UK Spec brakes are the best bang for buck. With some good pads, fluid, braided lines, brace master cylinder, etc. you won't need anything else unless you're a track day fiend Stick with OEM discs too, they're cheap enough to consider as disposable and you won't have to worry about cracking them (like with drilled). The larger spec 4 pot/ 2 pot Supra brakes are very good value for money and more than adequate for any road use. Quote Link to comment Share on other sites More sharing options...
