Message for Sheefa - Speaker Brackets
johnnyknox
I second that! Fantastic quality, and look so good as they are. :)
I have a few small problem with fitting though.
The existing screws don't seem to be long enough, and the original nylon retainers (door) aren't in good enough shape to take the new fitment.
Anyone know of somewhere I can get longer screws and some new retainers (for all of the door fitments really), that's if I can get the old ones out!
I will probably spray them black this week and try at the weekend to fit them again.
I had the same problem, try drilling the 3 holes deeper. Not too dep tho!
This will allow the screws to grip better. Worked for me. :)
I posted in the original Group Buy thread that the screws would not be long enough and you either need new, longer ACME screws, or remove the nylon retainer and use bolts. If you drill out the brackets any more than I have already, you will significantly weaken the mounting points.
