Chris and Alana Posted April 15, 2007 Share Posted April 15, 2007 I have a boost problem that seems to be getting worse but I just can't find it When I put my foot down the first turbo usually boosts to about 11psi but lately it only boosts to 9psi and then when the second turbo comes on it boosts to 14-15psi but it usually boosts to 16.5-17.5psi. This isnt the only problem because when Im crusing along and plant my foot, the auto drops a gear the engine hits high revs and then I get about 3psi boost now it used to do this but not that much but its getting alot worse now. If I left my foot on the loud pedal until it chaged gear it used to boost normally but now even when it changes gear it still stays at 3psi until I take my foot of and plant it again, even then I have to try a few times to get boost again. What could this be? Could it be more than one problem? Iv searched for loose hoses but couldnt find anything in that department, Iv read it may be the EGCT (I think) but how do I tell?. This problem is getting worse and annoying because its making my car horrible to drive I dont even like to try and overtake now . Any advice would be appriciated, I would really like to get this solved. Envy isnt far from me but I would like to see if I could fix it myself and save alot of money if I can. Thanks guys. Link to comment Share on other sites More sharing options...
edge Posted April 15, 2007 Share Posted April 15, 2007 I had a problem with dropping a bit of boost before number 2 came in. The hoses looked ok at first glance suntil i started taken them off then all became clear. I remember someone having a very similar problem to you the other day so hopefully they will see this. CW is a good person to ask. Link to comment Share on other sites More sharing options...
Suprasteve Posted April 15, 2007 Share Posted April 15, 2007 i think you have 2 seperate issues. The first issue with not as much boost as in the past could just be the warmer weather we're having, may be worth getting a boost controller and cranking it up a little ? The second issue where you drop down gear and plant it, it sound like the second turbo isn't kicking in. This appears to be a common problem but i've yet to see a straight forward answer - probably cos there isn't one. Link to comment Share on other sites More sharing options...
Ric Posted April 15, 2007 Share Posted April 15, 2007 EGBG OR CV which ever it is The VSV near the water pump, ive lost count how many times this has been mentioned in the last 2weeks Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 I had a problem with dropping a bit of boost before number 2 came in. The hoses looked ok at first glance suntil i started taken them off then all became clear. I remember someone having a very similar problem to you the other day so hopefully they will see this. CW is a good person to ask. What was wrong with your hoses? were they split? So do you think it is worth taking them all off and inspecting them individually? Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 Iv looked up this thread http://www.mkivsupra.net/vbb/showthread.php?t=35926 and it seems very similar to problem 2. If so then it looks like my EGCV is dicky, what do you guys think? Also is the part I would be after an EGCV vsv? Does anyone have a picture of where this is located and what it looks like? I seen that Ian has put some pics up but I cant make out exactly which one is the EGCV vsv or what it looks like. Thanks for your help so far Link to comment Share on other sites More sharing options...
Ric Posted April 15, 2007 Share Posted April 15, 2007 im sure i posted in this thread? Link to comment Share on other sites More sharing options...
RobSheffield Posted April 15, 2007 Share Posted April 15, 2007 im sure i posted in this thread? Who said that Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 15, 2007 Share Posted April 15, 2007 As PM'd... I have a VSV sitting beside me mate Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 Thanks Steve Il give all my hoses a check when I change it aswell and hopefully that will be that. Thanks again. Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 15, 2007 Share Posted April 15, 2007 Np. Your slowly taking all my Supra goodies away :'( lol Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 LOL. I was going to say aswell actually that if/when you upgrade your FMIC let me know (If you dont mind) and I may be interested in your 2row Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 15, 2007 Share Posted April 15, 2007 lol np I've got someone wanting my exhaust and wheels as well. Not gonna be much left lol Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 next time I pop round youll have a silver shell on bricks, lol Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 15, 2007 Share Posted April 15, 2007 lol no change there then On a plus side she seems to be running a bit better now You might get your run out in a single after all Link to comment Share on other sites More sharing options...
Steviekid Posted April 15, 2007 Share Posted April 15, 2007 Also is the part I would be after an EGCV vsv? Does anyone have a picture of where this is located and what it looks like? You can test the VSV like this. If it checks out stick a foot pump on the actuator itself. The valve should open smoothly with around 7psi of pressure. You can see the EGCV below the turbo heat shield. The VSV is above the alternator (the one of the left, the one on the right is the wastegate VSV). Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 Yeah sure, I would love a run out it will be good to see what a single feels like. Thanks steve Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 You can test the VSV like this. If it checks out stick a foot pump on the actuator itself. The valve should open smoothly with around 7psi of pressure. You can see the EGCV below the turbo heat shield. The VSV is above the alternator (the one of the left, the one on the right is the wastegate VSV). Thanks for that, very helpful. Steve has a spare vsv he is kindly donating so if I get stuck at least I know how to check if they are working ok. Thanks again Link to comment Share on other sites More sharing options...
edge Posted April 15, 2007 Share Posted April 15, 2007 What was wrong with your hoses? were they split? So do you think it is worth taking them all off and inspecting them individually? Some had little splits on the ends. When i took some off i found that the holes had become much wider. Just used some 1/4 (6mm) fuel line from halfrauds. Link to comment Share on other sites More sharing options...
Chris and Alana Posted April 15, 2007 Author Share Posted April 15, 2007 Some had little splits on the ends. When i took some off i found that the holes had become much wider. Just used some 1/4 (6mm) fuel line from halfrauds. Ahh, good to know. Il buy some of that before I strip my car to bits in search of dodgy hoses. Thanks. Link to comment Share on other sites More sharing options...
