RedM Posted April 14, 2007 Share Posted April 14, 2007 Right then, I've removed the centre cap on my stock 17s and right in the centre of the wheel/hub section (not the cap) is a threaded thing about two inches across. What does this bit do? Also, there is a hole in this part with a split pin through it. This pin appears to prevent something that looks like a cookie cutter from moving although it has some play in it. What is the cookie cutter thing? Next week: There's a red button next to my auto shift. What is it? Link to comment Share on other sites More sharing options...
Guru Posted April 14, 2007 Share Posted April 14, 2007 Whats a cookie cutter? Link to comment Share on other sites More sharing options...
RedM Posted April 14, 2007 Author Share Posted April 14, 2007 Whats a cookie cutter? Same as a pastry cutter. Link to comment Share on other sites More sharing options...
Steve Posted April 14, 2007 Share Posted April 14, 2007 The end of the drive shaft, with a cotter pin to stop the nut coming undone. Link to comment Share on other sites More sharing options...
RedM Posted April 14, 2007 Author Share Posted April 14, 2007 Is the cookie cutter thing the nut? Link to comment Share on other sites More sharing options...
Guru Posted April 14, 2007 Share Posted April 14, 2007 Same as a pastry cutter. Still don't get it. I have a gf so don't go in the kitchen much **Runs and hides like a coward** Link to comment Share on other sites More sharing options...
Steve Posted April 14, 2007 Share Posted April 14, 2007 No its just a cap that sits on the nut Link to comment Share on other sites More sharing options...
JustGav Posted April 14, 2007 Share Posted April 14, 2007 There we be a castle nut on the end of the drive shaft... looks like a but with little bits of metal above the nut head. Through the bolt there will be a hole, the split pin goes into the whole and through two of the castle nut bits to make sure it doesn't spin off... Link to comment Share on other sites More sharing options...
Steve Posted April 14, 2007 Share Posted April 14, 2007 There we be a castle nut on the end of the drive shaft... looks like a but with little bits of metal above the nut head. Through the bolt there will be a hole, the split pin goes into the whole and through two of the castle nut bits to make sure it doesn't spin off... Or the more technical answer Link to comment Share on other sites More sharing options...
RedM Posted April 14, 2007 Author Share Posted April 14, 2007 I've worked it all out now. Cheers fellas. Should I admit to panicking for a second or two when I couldn't see any of this on the front wheels? Link to comment Share on other sites More sharing options...
_Rob_ Posted April 15, 2007 Share Posted April 15, 2007 Should I admit to panicking for a second or two when I couldn't see any of this on the front wheels? LOL, no keep quiet on that one mate! Link to comment Share on other sites More sharing options...
RobSheffield Posted April 15, 2007 Share Posted April 15, 2007 Should I admit to panicking for a second or two when I couldn't see any of this on the front wheels? Probably panic more if you DO find it on the front wheels, as that will mean your car is actually a..... Nissan Skyline Link to comment Share on other sites More sharing options...
