carl0s Posted April 13, 2007 Share Posted April 13, 2007 Having sized my restrictor ring apprioriately, I'm still not happy with the performance I'm getting. The car hits its maximum of 18psi at very high speed in top gear on the motorway. Below that, it sees perhaps 16.5 psi-ish. In first & second gear, it doesn't see more than 15psi. So, I guess I need an electronic boost controller which will bypass the wastegate to obtain 18psi in the lower gears, and still make sure I don't go above 18psi in the higher gears. That's right isn't it? Any recommendations? I want something that I can set and forget, and hide any controls inside the dash below the radio so you don't actually know it's there. Quote Link to comment Share on other sites More sharing options...
dandan Posted April 13, 2007 Share Posted April 13, 2007 I had a blitz dual solenoid boost controller and was more than happy with it. Quote Link to comment Share on other sites More sharing options...
bolarbag Posted April 13, 2007 Share Posted April 13, 2007 I've just bought a HKS EVC6, so i may be selling my HKS EVC 3, need to get it out the car first...great piece of kit, hope evc 6 is as good...wont know til the cars back on the road about 5months down the line! but failing that...if you dont want a boost controller cant you just buy a mechanical adjustable boost controller, think their pretty cheap too Quote Link to comment Share on other sites More sharing options...
carl0s Posted April 13, 2007 Author Share Posted April 13, 2007 A mechanical one would raise boost across the whole speed/gear range though, so I'd overboost in higher gears. A "ball and spring" type supposedly shouldn't, but I had a bad experience with those POSs. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 13, 2007 Share Posted April 13, 2007 I've just got the AEM Tru-boost controller and i'm more than impressed with it Quote Link to comment Share on other sites More sharing options...
