Any decorators?
Jake
How the f*ck do you get old emulsion off plaster?
We want to paint the walls in our hall and stairs. We've stripped the wallpaper off but underneath is a horrible pink emulsion that is half blistered and cracked and half welded to the wall. No amount of scraping seems to shift it much but there's no way we can just paint over it.
I've tried sanding it (takes forever)
I've tried paint stripper (makes it a sticky mess on top but still doesn't come off really)
Any tips?
Sanding or sandblasting.
Or just give it a rough sand with a random orbit sander with course pads, then paint with UHU glue 50/50 with water to make the surface stable and adherent to the next coat of paint, then paint on top once thats dry.
Guest gzaerojon
how about wall paper stripper?
but dont hold it on there to long else it will bring the plaster of.
been there, got the T-shirt :innocent:
I have just been through this Jake, I was pissed off with seeing lines after decorating so stripped the lining paper off and used a orbital sander on the old paint underneath. It creates a right mess with the dust so seal all doors properly with polythene and masking tape
