which rad haste or koyo?
Paul372
am looking to buy a new rad but mr toyota wants £296 plus vat for a standard rad so i ve phoned around and had a look around and saw these two aluminium rads on ebay its the best deal i ve come across, haste is £250 and the koyo is £295 what one is best out of these two rads, what one do you think i should put on my twinturbo japspec auto, i was told there are striaght replacements for my standard rad and no mods needed, your suggestions would be a big help thanks are manual and auto the same
http://cgi.ebay.co.uk/Haste-93-98-Toyota-Supra-JZA80-Manual-Aluminum-Radiator_W0QQitemZ230115914097QQihZ013QQcategoryZ72205QQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/Koyo-Radiator-1993-1998-Toyota-Supra-JZA80_W0QQitemZ250100653491QQihZ015QQcategoryZ10428QQrdZ1QQcmdZViewItem
As Jake said mate. I run a Koyo which is brilliant, but you'll need a transmission cooler too.
Stock rads are excellent and only break after heavy mileage normally. Cooling wise, they're perfect for BPU up to small/med singles I'd say.
Personally, I like a bit of bling too and the Koyo has a thicker core. Just get a tranny cooler for your autobox and mount that in the side pod of the bumper or on the back of your FMIC - if you have one ;)
Koyo is proven but tbh I'd take a chance on the Haste rad as it looks like a decent quality item going by the listing.
As mentioned, you'll need a Fluidyne ATF cooler to go with it and run your auto trans fluid lines to this in one of the front bumper side vents. They sell for around $50 from the states.
Cheers,
Brian.
a lot of people have fitted the koyo mate and fitted a tranny cooler, never heard of the haste rad
__________________
what rad have you got, have you got a koyo rad did you fit it yourself or got a garage to do it if so what garage
