Guest gunner Posted August 12, 2004 Share Posted August 12, 2004 Hello all i am a new boy, I have had my silver j spec TT auto for just a month and i am loving it, however i have a few queries i hoped you might help me with, It has 2 greddy gauges mounted on an "A" pillar, boost and EGT what is the standard boost pressure and what temp should i expect the EGT to show ie. when hot. It also has an HKS EVC 3 which is set to 'monitor' at the moment i really don't understand the benefit of this, as i'm not sure i want to up the boost just yet. I really don't know what else has been done apart from an HKS BOV and induction kit and a fat exhaust, 18" alloys and side skirts. Would it be advised to get a dyno reading done as i think it can be done in Northampton? A nice chap leaned out of his van in Northampton recently and told me to look this club up, so cheers whoever you were. Sorry for the essay! any thoughts gratefully appreciated. Link to comment Share on other sites More sharing options...
Matttrd Posted August 12, 2004 Share Posted August 12, 2004 Welcome aboard, sorry can't help ya sure someone will be along shortly though. Link to comment Share on other sites More sharing options...
suprz_rz Posted August 12, 2004 Share Posted August 12, 2004 Standard boost is 0.8 bar. I dont know for sure, but EGT I believe is safe under 800 deg. Link to comment Share on other sites More sharing options...
Hy-Performance Posted August 12, 2004 Share Posted August 12, 2004 Hi, Welcome, im pretty new myself Always a good idea to get your car on the dyno so it can have a good check over Cheers, Chris Link to comment Share on other sites More sharing options...
MR.B Posted August 12, 2004 Share Posted August 12, 2004 Welcome aboard gunner Link to comment Share on other sites More sharing options...
Supragal Posted August 12, 2004 Share Posted August 12, 2004 hello and welcome- well done to that van man for plugging the club Have you tried using the search button? not being sarky but theres lots of great info on here thats already been covered. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted August 12, 2004 Share Posted August 12, 2004 Hello and welcome Link to comment Share on other sites More sharing options...
Ian R Posted August 13, 2004 Share Posted August 13, 2004 hello and welcome Link to comment Share on other sites More sharing options...
Faye Posted August 13, 2004 Share Posted August 13, 2004 Hello Link to comment Share on other sites More sharing options...
Roy Posted August 13, 2004 Share Posted August 13, 2004 hi gunner and welcome (pls don't tell me you are an arsenal fan ?). i suspect the answer to your egt question will depend where the probe has been inserted. you will need to find that out first before determining what the accepted (?) temps should be. HTH ... Link to comment Share on other sites More sharing options...
jusie Posted August 13, 2004 Share Posted August 13, 2004 Hello . Ive only been on here a short while but the board is great for everything you need to know about your new supe Im sure you will have lots of fun driving it. Link to comment Share on other sites More sharing options...
hogmaw Posted August 13, 2004 Share Posted August 13, 2004 Originally posted by jusie Hello . Ive only been on here a short while but the board is great for everything you need to know about your new supe Im sure you will have lots of fun driving it. I second that, only been here a couple months myself Link to comment Share on other sites More sharing options...
Bill Prawn Posted August 13, 2004 Share Posted August 13, 2004 Hello mate:) Another newbie from the county of squires and spires. I bet i'm 'gunner' see you around. Link to comment Share on other sites More sharing options...
Steve W2 Posted August 13, 2004 Share Posted August 13, 2004 Stnadard boost is around 0.8 bar, as for the EGT's I think if they are below 800oC you are okay as standard. If your car is decatted and running more than stock boost pressures then your EGT will inevitably be higher. If you have very high EGT's whilst running 1.2 Bar (for example) then check that both moggies have been removed. If the first one is still there that won't be helping the heat situation. Also as somebody else has mentioned you need to check where the probe is inserted ( ) before you worry to much about the EGT temp's:) Link to comment Share on other sites More sharing options...
Guest gunner Posted August 13, 2004 Share Posted August 13, 2004 Thanks for all the welcomes and advice, it's quite a steep learning curve changing from an average Joe type car, but nice to be part of an elite group!! cheers And no i'm not an Arsenal fan, it's a nick name from my Army days, Liverpool have always been my team! Link to comment Share on other sites More sharing options...
Green Peace Posted August 13, 2004 Share Posted August 13, 2004 Welcome mate! Si Link to comment Share on other sites More sharing options...
colsoop Posted August 13, 2004 Share Posted August 13, 2004 hello and welcome aboard. Your not a gun bunny are you? Link to comment Share on other sites More sharing options...
