Little bit of help please
Guest Geneb
Guest Geneb
ok guys i admit im a numpty when it comes to this wheel and tyre stuff.
i need help on what tyres to buy that wont rub on my wheel arches when i turn the wheel.
my current tire sizes are Front 225/50/16 Rear 245/50/16
and i have stock suspension not lowered
these are the alloys i have bought any help would be deeply appreciated
http://www.mkivsupra.net/vbb/showthread.php?t=106466
The offsets are far from ideal, they'll stick out into the wheel arch.
I have a set of 18x10 with +48 offset on the rear and even these rub the arch when the suspension is compressed.
Do you know the tyre size you're planning on fitting?
Guest Geneb
was thinking fronts 235/35/18 rear 255/35/18
would really like to go 245/35/18 275/35/18 but think they may rub
Guest Geneb
To be honest, it's gonna be hard to tell but i'd go for quite a narrow tyre to fit those wheels given the offsets.
will more than likely need to have the arches modified as well i would imagine.
Modified ahh fook:(
looks like an ebay job
Guest Geneb
when i say modified you'll quite possibly just need some rolling or shaving done.
at worst, it's an excuse to buy yourself some veilside overfenders :D
will i need paint as well as rolling?
rolling can be tricky i believe as it may crack the paint.
shaving is much better as it merely trims away the inside of the arch but you can't shave too much away.
in short, if it works no you won't need paint.
trouble is you'll only tell once the wheels are fitted and on the car.
Guest Geneb
If in doubt, give Ibrar a ring as he is one of the most knowledgeable guys i know regarding wheels and offsets etc.
gonna call him tomorrow bud thx for that, hey col do you still want them bits if not no prob bud
