cheekymonkey Posted April 10, 2007 Share Posted April 10, 2007 Hi All I feel like I'm over-using this forum but it's such a great resource... with time I'll be able to help with newbie ish questions as well. I get a creaking from the rear of the car when going over speed bumps etc. More obvious when there's a back seat / boot full of camping gear! It's seems to be even - not coming from any particular side. Can anyone suggest the most likely cause of this and a possible resolution? Cheers! Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted April 10, 2007 Share Posted April 10, 2007 rear sub frame about to drop off ... Could be your boot rattling, you may nedd some new rubber mounts Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 10, 2007 Author Share Posted April 10, 2007 rear sub frame about to drop off ... Could be your boot rattling, you may nedd some new rubber mounts Yeah, I like the sound of that section option much better Any way to check for sure? Quote Link to comment Share on other sites More sharing options...
mattanna Posted April 10, 2007 Share Posted April 10, 2007 Most likely boot mounts, they go hard after a few years and cause boot lid to rattle on them, more of a rattle than a creak though Quote Link to comment Share on other sites More sharing options...
Sheefa Posted April 10, 2007 Share Posted April 10, 2007 Most likely boost rubbers - common fault. Easy way to check - get a new set and fit them Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 10, 2007 Author Share Posted April 10, 2007 Most likely boot mounts, they go hard after a few years and cause boot lid to rattle on them, more of a rattle than a creak though I will take a look later, see if they looked aged. Hoping that's what it is. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 10, 2007 Author Share Posted April 10, 2007 Most likely boost rubbers - common fault. Easy way to check - get a new set and fit them Right. I have the part number from a search but now need to know if this is the sort of thing I'd get from a main dealer, or from a nice person on here? Also - if I order one off 67293-14051 would I get 1 set, or 1 rubber only? Quote Link to comment Share on other sites More sharing options...
Glosphil Posted April 10, 2007 Share Posted April 10, 2007 Boot rubbers, I agree Mine did this, I kept spraying halfords spray grease on them and it went away, its now seemingly absorbed a load and I dont need to do it anymore. Good to know before you try and buy and fit new ones. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 10, 2007 Author Share Posted April 10, 2007 Boot rubbers, I agree Mine did this, I kept spraying halfords spray grease on them and it went away, its now seemingly absorbed a load and I dont need to do it anymore. Good to know before you try and buy and fit new ones. Cool. Might try that. If in doubt, apply Lard. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted April 10, 2007 Share Posted April 10, 2007 Boot rubbers, I agree Mine did this, I kept spraying halfords spray grease on them and it went away, its now seemingly absorbed a load and I dont need to do it anymore. Good to know before you try and buy and fit new ones. How much was the spray grease? The rubbers are £4.99 on ebay Quote Link to comment Share on other sites More sharing options...
chilly Posted April 10, 2007 Share Posted April 10, 2007 I replaced mine last year and the noise went. Apparently they are cheap from Mr T (its a first). You only need to replace the lower ones, which are a bstard to undo. Be careful not to loose patience like i did with the screws and end up having to hacksaw them off. Quote Link to comment Share on other sites More sharing options...
Kranz Posted April 10, 2007 Share Posted April 10, 2007 Be careful not to loose patience like i did with the screws and end up having to hacksaw them off. Like he said, they can be a bit*ch to get off. It helps to WD40 the screws from the top and from behind a few days before. If you can't undo the screws you can hack/pull the rubber off the backing plate and get mole grips on the heads and a bit of heat behind with one of those micro blow torches & spray with WD40 (not while heating or else ). Comes out nice and easy Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 13, 2007 Author Share Posted April 13, 2007 Hi All I had a look at this last night. I think the boot rubbers have already been replaced, since there was a small bag with an old one in it supplied with the car. Also - I had the boot open, and manually rocked the back end up and down, and got a little bit of the same noise. So I guess it's either shocks or suspension, any ideas anyone? Thanks! Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted April 13, 2007 Share Posted April 13, 2007 if its not the rubbers (i would still replace them for peace of mind and to rule them out as a problem) it could be the sub frame bolts need to be re-torqued, do you have after market suspension or top mounts? Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 13, 2007 Author Share Posted April 13, 2007 if its not the rubbers (i would still replace them for peace of mind and to rule them out as a problem) it could be the sub frame bolts need to be re-torqued, do you have after market suspension or top mounts? I may try and go over a speed bump later with the boot open to rule that out *grin* AFAIK I don't have any aftermarket suspension bits. I will probably find an expert for that sort of thing, engines I am fine with but structural things scare me. Do you think any competent garage would be OK with this sort of thing? Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted April 13, 2007 Share Posted April 13, 2007 if you do a search you should find the correct torques for the sub frame bolts, any good garage should be able to check them for you, i personally would get an expert to check the suspension - just for peace of mind Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted April 13, 2007 Author Share Posted April 13, 2007 Thanks mate Quote Link to comment Share on other sites More sharing options...
