Spoilerless Help
boombastictiger
Ok I have seen enough pictures and enough cars to know I want to go spoilerless..Might aswell give it a try. However what do I need to do? How hard is it? And where can I get these plugs that people have been saying to use?
What is involved when taking the spoiler off is it a simple job of simply unscrewing bolts?
EDIT: OK OK I HAVE GONE SPOILERLESS!!!! Took about 20 mins to get the spoiler off..Cleaned up the dirt that was left and tcut waxed it in black to try and make it look a bit shiny..There are some marks from the spoiler which I couldnt get rid of but apart from that im VERY happy :) ...Car looks alot more smooth and more classy..From the side it really does look hot hot hot...It does give you the impression that its a bit wider to...Oh yeah I got some grommits from halfords....I got a box of mixed however I needed 4 of 1 particular size but there was only 3 in the box so im going to get some more tommorow. ALso I need to get a oblong (spelling) shaped one for the middle hole....check it out tell me what ya all think..
The pictures really dont do it justice...In the pics it looks a bit naked but thats because of the angle I took them at and the slope on my drive....In real life it really does look beautiful...
Guest Phillw454
4 bolts the 2 fixings in the middle that unclip.
I did mine sunday:)
Farily easy, i duno about the plugs, i just used filler sanded down and painted over. Took less then 2 hours.
If you need any advice just drop me a pm
QUOTE]
LOL i had that with the grommits today too. Got home started to fit them then realised i was one short:rolleyes: But with the center hole i just used the next grommit size up till i find a better fit. If i do find a good fit I'll let you know where i got it from.
Your cars looking good by the way fella:cool:
just to let you all know you can pick up the grommets from halfords, i believe the size you want to by is 6mm and 8mm. They managed to fit into the wierd oblong shaped hole...
The only problem I have now is getting rid of the stubborn marks left over from the spoiler....!!! How could I get rid of them marks? Metal cleaner? but then would it damage the paint?
I did this myself yesterday, i also removed the aerial and wiper arm. I like the look but will leave it for a couple of weeks before deciding fully.
It looks a bit tatty though as some of the clear coat has peeled under the spoiler but i would rather decide while its reversible if i like it or not ;)
