Drain Covers In The Middle of the road!!! WHY!!!
boombastictiger
Why why why why do they have drain covers in the most inconvinient places on the road...Its so painful going over them....And rather than place them in the middle of the road they put them on the left or right side, right where the tyres would normally go over.... I always get caught out by these stupid things, swerving all over the place, why cant they just put them on the pavement!!
If it's a relatively new sewer, the line of the sewer is dictated by existing services - underneath the road you have various other pipework and cables, such as gas, mains electricity, street lighting, water mains, BT, cable TV, etc.
Generally, you'll only find that these services cross the road, as the majority of them run inside the footpath.
Also, if the newer sewer was replacing an older/smaller/damaged sewer, then it's more economical to install the new sewer on a new route rather than shutting off the old sewer for the duration of the works.
It's good practice on new build schemes to place manhole lids between the normal track of people's wheels, but this is very rarely possible on most drainage jobs.
Has that helped? :)
I know what you mean mate!! I had a tyre pop on one of these damg sunken drain covers (it just let all the air out as the bead came off the rim when it hit), resulting in a slow drive the 1/2 mile home at 6 in the morning in the rain with a flatty.
Word to the wise...... if the tyre pressure is low a sunken drain cover can cause the tyre to totally deflate. Keep 'em up to pressure guys! :blink:
Had my car 8 weeks and still not checked the tyre pressures Steve!!:blink:
Just don't tell the rozzers!!;)
H.
