speddynille Posted April 9, 2007 Share Posted April 9, 2007 Im installing a car alarm in my supra now and there are some wires that i dont find in the car! Door trigger wire Hood pin wire and parkinglights wire (negative) And I found this on the internet it is not to my alarm but it shows what colours the wires are in the supra. http://www.commandocaralarms.com/wiring/1994/Toyota/Supra Do you think its right? Im very thankful if somebody can help me with this and maybe get som pictures exactly where its located? Link to comment Share on other sites More sharing options...
merckx Posted April 10, 2007 Share Posted April 10, 2007 I made most of my connections in the drivers footwell fuse box, the one on the right when you remove the plastic trim. Door trigger , the blue connector athe very top left - green wire , normally +12v, goes to 0v when the door is opened. Hood pin wire , my J spec car didn't have this as it didn't have a factory fitted alarm , so I fitted my own bonnet switch. Parking lights, not sure. You really need a multi meter to check them out for yourself to make sure. Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 I found the door trigger, one good thing =) my does not have a facory alarm either so how did you do with the hood pin wire? I think I found the cable for the parking light but not sure, if anybody else now, they are happy to answer =) Link to comment Share on other sites More sharing options...
merckx Posted April 10, 2007 Share Posted April 10, 2007 my does not have a facory alarm either so how did you do with the hood pin wire? I fitted my own switch at the front. Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 ok, how does it looks like? any pics? Can you try to explain it, beacuse I dont got a clue how to do it. Link to comment Share on other sites More sharing options...
merckx Posted April 10, 2007 Share Posted April 10, 2007 The switch needs to be fixed to the bodywork of the car with a steel screw (red arrow) . Solder your alarm wire to the switch (blue arrow) You need to make a hole for the switch to fit into, position shown in pic. Adjust the length of the the switch by cutting it if necessary so the switch is pushed open when the bonnet closes. Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 I found that I have gotten a switch that looks almost like that in my alarm So I will do like in the picture. One more thing for now Where did you find the oil sensor wire? Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 i can help you Link to comment Share on other sites More sharing options...
merckx Posted April 10, 2007 Share Posted April 10, 2007 One more thing for now Where did you find the oil sensor wire? For the alarm? I haven't got a clue where the oil sensor wire is. Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 i will tell you every wire you need to go to, to totally install you alarm system. Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 why do you need the oil sensor wire? Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 yes its for the alarm. it is a alarm with a remote start so its maybe needed there I dont know. Ok, can you tell me the oil sensor wire brake input wire parking light outpout, and even where the parking light relay jumper (jp2) is located. it says I must set it to proper polarity. Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 you are doing this all the long way round it sounds to me that you need a good installer Hint Hint Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 sounds like you may even need a qualified industry trained, 19 years experienced sort of person that installs them every day on jap cars. what to do????? Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 ok, and what is that hint? maybe you perhaps? Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 deeeerrrrrrr Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 bingo Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 do not ruin this thread, Im asking for som help for my alarm not you bragging about your work and how good you are. Do you want to help please answer the questions, you dont need to spam the thread... Link to comment Share on other sites More sharing options...
Guest msisupra Posted April 10, 2007 Share Posted April 10, 2007 you need to chill i can help you in every way you need, im just being a little enterprising thats all, sorry to offend. Link to comment Share on other sites More sharing options...
speddynille Posted April 10, 2007 Author Share Posted April 10, 2007 thats ok, I just thougt it was not so neccessary to post a new post with one word and so on.... But can you tell me then where I can find those wires in my supra? Thats the only problem that I have is finding the right wires. then I will be very thankful Link to comment Share on other sites More sharing options...
rottweilaz02 Posted June 26, 2018 Share Posted June 26, 2018 might be along shot but would anyone have the actual wire diagram for the remote start install Link to comment Share on other sites More sharing options...
