Cleaning Engine Parts
Jive
Hi peeps, as some of you may know my engine is partially stripped on my NA and I've got the opportunity to clean my air intake manifold - I don't think it's ever been touched apart from the day it was placed in the engine so a fair bit of grime has built up over the years.
Anyone suggest a good way of cleaning these sections up? I've tried using Autosol and Autoglym Metal Polish on the bits circled but it's not improving it a great deal (although I can see some improvement) but any ideas on how to clean really well would be appreciated :)
T.I.A. to lots of elbow grease methinks :D
Well for starters I just want to clean the crap off of there, if you look at the two pics you can see the dark grey bits in the areas I have done are like stuck on dirt and have tried about 4 or 5 applications to remove them. Just wanted to know the best way of getting it all off for starters, then I'll start work on the polishing ... especially now I know how to remove it all :D
That's great advise, thanks gents .. unfortunately I don't have a bench so looks like my Dads garage is gonna be required :)
Will the scotchbrite mop get in all the nooks and crannies ok?
Not i wouldn't you would need to get some sheets or pads as well.
If it was me i would pay for the blasting to be done (once you have masked up areas that you dont want blasting)
Buying this that and the other will add up to around the same cost of getting someone to blast it fore you then of course you have to spend your own time doing the work ;)
Don't get them sand blasted, as they will corrode more easily, glass bead or another polishing type of media blasting is better, and you will need to mask up and be prepared to make sure that any residue is completely cleaned out;) i used to run a blast cleaning company, so i know what i'm on about.
Shame you dont anymore :( I like the finish that glass beads give.
So I take it that it's better to get it glass blasted than sandblasted if you want to get it looking smoothe and shiney?
Has anyone got a local company in Hampshire that they can recommend seeing as I really want to get this done this week while my car is off the road?
