Awesome R32 In Japan 750 ps
Jurgen-Jm-Imports
:( right guys this is not my stock and still in jp so be quick if interested i have ran out of funds now :(
R32 block used
 HKS 2.8L piston KIT STEP ‡U
 (HKS forged full counter crank 77.7mm stroke)
 (HKS option forged Conrods 21 pin)
 (HKS forging 87„U piston nickeling (21 pins))
 NISMO metal
 TRUST crank cap volt/bolt nut KIT
 NAPREC RB26 drag KIT
 (NAPREC Big valve)
 (combination valve guide)
 (heatproof cast iron seat ring)
 (valve guide replacement)
 (seat ring replacement)
 (seat cutting for race, extended and adjusted)
 (water jacket air hole processing)
 (oversize jacket plug size processing)
 (1.0mm surface research)
 HKS valve stem seal set
 NAPREC RB26 combustion chamber full machining
 (full circle form)
 Tomei PRO cam IN260 MD lift 10.25 EX260 MD lift 10.25
 Tomei valve spring B retainer
 HKS Gasket
 throttle gasket
 TRUST bulk OIL pump
 Tomei OIL pan baffle plate
 TRUST T - 7829 D turbine KIT
 stainless steel turbo EX manifold
 wastegate valve type C
 front pipe
 ENDLESS super surge tank
 NISSAN genuine infinity throttle
 TRUST cam sprocket
 TRUST strengthening timing belt
 TRUST clearing timing belt cover
 NEEDS OIL filler cap
 NEEDS OIL catch tank
 NEEDS one off 90 pie stainless steel muffler
 NEEDS suction pipe
 TRUST 3 layer type intercooler
*FUELING*
 SARD collector tank
(265L~2 fuel pump)
 NISMO in tank bulk fuel pump
 SARD top feed 700cc injector
 TRUST fuel delivery (2 systems) (return 8 pie aluminum pipe )
*Cooling*
 all aluminum 3 layer type
 BILLION low temperature thermostat
 N1 water pump
 TRUST aluminum pulley KIT
 HKS OIL cooler KIT
 SARD air reservoir tank
 SAMCO silicon hose KIT
 carbon dynamic aerofoil
* Drive*
 HKS dog 6 fast mission Ver ‡U (NO travelling after O/H)
 HKS triple plate clutch (metal) (NO yet travelling after O/H)
 ATS F1.5WAY LSD
 ATS R2WAY LSD
 GTS-4 4.3 final gear SET
 TRUST F bulk diff. cover
 TRUST R bulk diff. cover
* Underside*
 APEX N1 PRO height pitch KIT
 ikeya Formula Front lower arm & tension lot
 ikeya Formula Front roll center adjuster
 Other ikeya Formula Suspension parts
 HPI front adjustment type upper arm
 CUSCO rear upper arm
 R33GT-R rear member transplantation
 rear member rigid welding stop
 rear lower arm pyro conversion
 ARC front stabilizer
 ARC rear stabilizer
* Body*
 HKS Kansai F lower breath bar
 HKS Kansai R lower breath bar
 HKS Kansai Paint Co., Ltd. center bar
 HKS Kansai mission member color
 HKS Kansai F tower bar
 HKS Kansai R tower bar
 SAITO 10 point type roll gauge (dash penetration)
 CUSCO rear pillar bar
* Brake*
 Alcon 4POT carry per &355 rotor KIT
 Alcon 4POT carry per &332 rotor KIT
The brake master cylinder for  N1
 WILWOOD brake ballancer
* Exterior*
 FRP front wide fender
 rear fender processing
 TRUST front bumper
 TRUST rear bumper
 TE37 limited 9.5J offset }0 black
 TOPSECRET PRO carbon parts
 TOPSECRET PRO
 pearl white all paint
 carbon bonnet
* Controller &CPU™
 BLITZ dual SBC I-D boost controller
 BLITZ dual POWER METER I-D
 HKS circuit attacker
 HKS F-CON V-PRO gold model
 FIELD engineering and research torque split controller
 SARD-STACK ST200 FOR TACHOMETER
 SARD METER PANEL
* Interior*
 RECARO driver's seat SPG
 RECARO suicide seat SR- ‡V
 quick release boss
 MOMO steering wheel
 TAKATA 4 point type seat belt
 battery rear transplantation
PM me for price but for the curious a ball park figure its under 20k but over 16k
done mate, i have give him a top price on the r33 but we need a quick answer on that one ;)
He just sold his Ferrari and has the cash so just hunting for the right jap car now, i just chatted with him and think the 33 fits the bill, lets see, he knows he has to move quick;)
